New 2 piece Rotor Options
Old 01-29-2017, 01:55 PM
LC MotorSports
Former Vendor
LC MotorSports's Avatar
Default New 2 piece Rotor Options
LC MotorSports new 2 piece Porsche disk assemblies pricing is finalized!
While the first shipment has been delayed until the end of Feb we can with confidence post the pricing breakdowns.
All Ø299 mm x 24 mm Front (Boxster),
Ø299 mm x 24 mm Rears (SPC/Boxster/Spec996 fitments) as well as all cars that these fit.
$750.00 complete set (a set is 1 Left / 1 Right assembly)
$375.00 per assembly (an assembly is 1 brake ring (left or Right), 1 Aluminum hat of 7075 t6 and all hardware).
$225.00 per replacement rings.
$110.00 per hardware kit (kit for 2 complete assemblies)
$350.00 per replacement hat.
Ø318 mm x 28 mm Front SPC/Spec996 & Stock class cars as well as all cars that these fit.
$896.00 complete set (a set is 1 Left / 1 Right assembly)
$448.00 per assembly (an assembly is 1 brake ring (left or Right), 1 Aluminum hat of 7075 t6 and all hardware).
$275.00 per replacement rings.
$380.00 per replacement hat.
Ø350 mm x 34 mm Front
$1180.00 complete set (a set is 1 Left / 1 Right assembly)
$667.00 per assembly (an assembly is 1 brake ring (left or Right), 1 Aluminum hat of 7075 t6 and all hardware).
$385.00 per replacement rings.
$410.00 per replacement hat.
Give us a call or email to place your order.
Cheers,
Chris
Old 01-29-2017, 04:57 PM
ianacole
ianacole's Avatar
Slotted rings for the 986, or solid?
Old 01-29-2017, 05:02 PM
LC MotorSports
Former Vendor
Slotted
Old 01-30-2017, 12:25 PM
Mvez
Mvez's Avatar
Images? I'd like to see the hardware arrangement.
Old 01-30-2017, 01:37 PM
ianacole
ianacole's Avatar
Originally Posted by LC MotorSports
Slotted
Awesome!
Old 03-03-2017, 12:25 PM
LC MotorSports
Former Vendor
The Delivery date from DBA Australia has been delayed AGAIN!.... I should know better by now.
They informed me today that the completion date is now end of March with a arrival date of April.
Now that said, I am arranging to AIR Freight several rings here to Satisfy your pre orders.
I apologize for the great inconvenience this has caused. We will work to make it right to all of you.
Regards,
Chris Whaley
Old 03-03-2017, 05:41 PM
Slakker
Slakker's Avatar
Do you have front and rear weight comparisons to stock for SP996?
Old 03-04-2017, 10:23 AM
LC MotorSports
Former Vendor
These are the Front assembly numbers.
Weights of Assembly: 17.8 lbs
(OEM drilled 18.8 lbs and I will weigh the slotted rotors again as a comparison)
Weight of rings: 16.1 lbs
Hat and Hardware: 1.7 lbs
These are the Rear assembly numbers.
(OEM drilled 14.1 lbs and I will weigh the slotted rotors again as a comparison)
Weights of Assembly: 12.71 lbs
Weight of rings: 11.01 lbs
We had targeted a lower weight (10 lbs front / 9 lbs rear) when we first tested these. (Sprint Style Fitment) But, after testing we increased the mass to better handle the thermal conditions and improve the service life of the fitment.
Old 04-04-2017, 11:26 AM
LC MotorSports
Former Vendor
The new Ø350 rings arrived yesterday.....
As soon as I get a create opened up I will post a Photo of the new Rings.
We are told the Ø318's shipped April 3rd, The Ø380's shipped March 20th.
Old 04-04-2017, 11:59 AM
onefastviking
onefastviking's Avatar
SPB ???
Did they change the rules to allow 2 piece in SPB and I miss it ?
All Ø299 mm x 24 mm Front (SPB),
Ø299 mm x 24 mm Rears (SPC/SPB/Spec996 fitments) as well as all cars that these fit.
Cheers,
Chris
Old 04-04-2017, 01:05 PM
ace37
ace37's Avatar
Originally Posted by onefastviking
SPB ???
They changed the post and I assume it was to address this question. I didn't see it permitted in the 2017 PCA SPB rules.
Old 04-04-2017, 02:20 PM
FeuerRacing
FeuerRacing's Avatar
SPB ???
You didn't miss anything. Rule 5.E. still states:
"One piece stock size steel rotors are required. Rotors may be cross‐drilled or slotted."
and there's been no ammendment since and don't expect us to change anytime soon if ever.
Quick Reply: New 2 piece Rotor Options
