Non HANS H&N Devices (Schroth, Simpson, Nexgen)
Old 03-23-2017, 08:10 PM
Sawborg
Sawborg's Avatar
I have the Flex. Just used it over the weekend and it felt great. As for the notch placement, the manual states that it should be between 0-45 degrees.
Old 03-24-2017, 10:26 AM
CosmosMpower
CosmosMpower's Avatar
Thanks that picture in the install guide is tiny and it's nearly impossible to see which way the notch is pointing. Still debating if I want to keep this thing. Everything about it just seems 2nd rate compared to my HANS. The hardware is even cheap, I mean a plastic base ring for the posts, come on Schroth.
Old 03-24-2017, 03:02 PM
crooster
crooster's Avatar
Necksgen Rev here. No comfort issues. The only time I remember it's there is turning my head to pickup the apex at 5B at Mosport!
Old 03-27-2017, 05:38 PM
stronbl
stronbl's Avatar
I use the Simpson Hybrid Pro. I find it very comfortable and works well with 3 point belts/seats and race seats 5/6 pt harness.
Old 03-27-2017, 06:11 PM
Gofishracing
Gofishracing's Avatar
NECKSGEN REV rocks.
Old 03-28-2017, 10:11 AM
ApexPerformance
ApexPerformance's Avatar
Below is the link to the instruction manual for the SHR Flex. Page 6 shows the anchor should be positioned between 0 and 45 degrees (similar to hans anchor) with the notch facing the rear of the helmet. Looks like your installation is correct.
https://www.schrothracing.com/docs/SHR_Flex_Manual.pdf
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
Old 03-28-2017, 11:39 AM
CosmosMpower
Thank you, one small issue I had when installing the anchors is how much to tighten it down. Too loose and it would spin out of position when trying to click in the tether end. Too tight and you can't push the spring down far enough to engage it.
Old 03-28-2017, 11:54 AM
jlanka
jlanka's Avatar
I tried the necksgen but as stated earlier, it rode back on my shoulders too much for my liking. I switched to the traditional HANS and don't have that problem.
Old 03-28-2017, 12:23 PM
ApexPerformance
Once the anchor is started on the helmet, I would put the tether onto the anchor, then tighten it down snug. We do that with HANS anchors if we don't have the tool to adjust the collar anchor during installation.
Old 03-28-2017, 12:25 PM
CosmosMpower
Good idea, I'll try that. Thanks
Old 03-28-2017, 03:54 PM
Gary R.
Gary R.'s Avatar
I haven't done any geometry recently but to me that slot angle is not 0-45, but 225-270 degrees from level. The left side would be 90-135 degrees.
Quick Reply: Non HANS H&N Devices (Schroth, Simpson, Nexgen)
