987 track build...
987 track build...
Pretty excited... It's taken a good year and a half to get the car to this point but I am hoping there will be an addition to the PCA Club Racing family later this year... I don't have her back yet but should pick it up this week. Custom cage by JPC fabrication, Fire suppression system in, KMP quick release wheel is in, AiM dash is in, custom door panels done by JPC, nets are done, switch panel has replaced the PCM/Nav unit, electrical cutout is done, harnesses installed to spec and she is good on min weight... Maybe 40 pounds heavy after the cage is in but pretty close... Now to get it back on the track!
Congrats! PCA Stock I Spec?
Basic Site Sponsor
Basic Site Sponsor
Received 2,888 Likes
Looks beautiful, Paul! Hats off to James and his crew, too.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Prepared I... Need to check with Geoff about aero still.
It's an 09 PDK ir... Yes to slicks 2009 Boxster S w/ Fabspeed Race Headers, Fabspeed Tracktec Exhaust, GT3 Master Cylinder, GT3 Brake Ducting, Bilstein PSS9 Coilovers, Bodymotion Racing PDK Cooler
Nice build.
Take all the rubber molding off the doors and top of windshield/a-pillar/rocker/b-pillar.
You can also pull some trim/plastic/lower dash on the driver's side.
Sometimes there is extra structure behind the center console that can go.
Lastly, you may want to pull your HVAC system and simply use bilge fans for defog function.
All of the above will help towards your weight goal.
Nice build.
Thanks Frank! Thanks ir!
1. Engine:.
A. As delivered from factory. No modifications after the air filter box or before the exhaust headers. Mass flow sensor
may not be relocated. Modifications before the engine side of the air filter box (e.g., aftermarket air filters,
modification of the stock air filter cover, omitting the air filter element entirely, ducting air without making openings in
tub or bodywork) are allowed.
B. Chips are free in pre‐OBDII cars, so long as the stock rev limit, and boost control on turbocharged engines, is retained.
Electronic fuel injection must retain stock ECU and KLR chip (if applicable), and the OBDII flash may not be altered.
Those were my really big questions about Stock I. It looks like everything else I would be compliant. What tire options does that leave me? I am still trying to interpret everything to the letter....
So any changes and I go Prepared J not Prepared I. I am still learning, Geoff had suggested Prepared I. Otherwise I slot into 09-13 3.4L 987.2 in GTB1 and I already have my 100 pound PDK weight hit and don't need to have wing envy anymore LOL...
TY as always!!
Need to speak to you about this to better understand. Been reading the rule books and there are a few things I am still unsure of...
1. Engine:.
So forgive my ignorance but I read this as Air filter changes are ok, but what about the headers themselves? Plenum and Throttle Bodies must remain Stock as well?
So what does Chips are Free but OBDII Flash may not be altered mean? I understand the no ECU tune part, but what does the Chips are free part equate to?.
TY as always!!
1. Engine:.
TY as always!!
Exhaust system is free providing the engine meets any local noise limit requirements. .... All components which serve only to control emissions may be removed, and cars are not required to meet emissions standards, but this does not permit altering electronic programming where chips, flashes, or ECUs must remain stock other than to remove an emissions related CEL.
Any DOT (or its European equivalent) approved, nationally marketed, generally available tire which is allowed on public roads is allowed, even if it is a “road race version” and its manufacturer does not recommend its use on public highways. “V” or higher speed rated tires are required for all cars, except those for which “V” rated tires are not universally available. In all cases, the speed rating of the tire must be equal to or greater than the speed potential of the vehicle.
Any modifications beyond this, like non-stock aero, ECU flash, upgraded brakes, etc. would push you into Prepared J. IPD plenum with GT3 throttle body would push you into GT class.
Your car would fall into Stock I where:
In essence, headers and exhaust are free. Cold air intake is free. ECU must remain stock - No flashes allowed. We are checking ECU flashes now at races. Plenum and throttle body most be stock. We check that frequently as well.
Tire wise, you can run Hoosier R7s or any other DOT "Race only" tire.
1. Back out ECU tune, Plenum and TB run Stock I (recommended)
2. Keep ECU, Back out Plenum and TB run Prepared J (Not recommended)
3. Go all in, keep ECU, Plenum and TB get a really big wing and run 09-13 3.4L 9872 GTB1 (Really Not recommended LOL)
So really, 1 choice but when I go through RennPoints it's funny, the lap times between the three are very very close or in some cases near identical.
So 3 choices:
I will send you a check for PCA rule interpretation services tomorrow morning, thank you as always!!
