Ear / noise protection
I just turn my hearing aids off LOL
BTW, active noise canceling just reduces the effective sound you hear, not the actual sound pressure level
it is also somewhat frequency specific. It works by generating an out of phase signal at the same frequency as the noise it picks up
(simplified explanation)
I've used a variety of them. I like the custom fit of the Radians but the comfort of the NoNoise ear plugs. Both work great and use both, depending on what I'm doing (karting, motorcycling, track driving, etc).
I had just decided to get some over-ear inserts for my helmet, to be able to take future coms, but also to cut down the noise a bit. Looks like they didn't do much ^^^ for one user. Can anyone else comment on them?
Foam ear plugs were a bit too much for me, but passing WOT SPBs hurts!
Wearing proper hearing protection is a bit disconcerting at first. You will get used to it
There is a big gap between what you think is only loud and what causes pain: that gap is still enough to cause permanent damage. Check OSHA stats.
https://www.creighton.edu/fileadmin/...protection.pdf
The SPB's are loud. Wait till someone goes by with open pipes.
Have the muffled helmet. Inside helmet looks like ear muffs. When put on helmet I cannot understand anything anyone says to me. This thing works amazingly. Cannot heat car at idle. When I race I use radio ear plugs and don't have to turn it all the way up to hear spotter.
Thx everyone for your inputs! The couple of the custom/molded solutions claim only 25-26dB NRR. Dan's MAX-1 claim 33dB NRR. I had to get some for early next week so before I started this thread I ordered these Hearos for $8.60 with Amazon Prime that also claim 33dB NRR:
https://www.amazon.com/gp/product/B00AJSY162
Will report how they work.
I used custom ear plugs and I have ear cups in my helmet. When using both, sound is pretty much muffled out but like Clarke, I can't hear anyone trying to talk to me.
When racing, I have custom ear buds and I don't have to turn the volume on my radio up.
True about using spit or water--even sweat that comes from racing can lead to an inner ear infection. There's a "lubricant" made specially for this type of application. It came with my last set of ear plugs.
WRONGLY ACCUSED!
Received 3,378 Likes
It might have to do with proper fitment?
As someone who has hearing loss from high volume music I can tell you that you want to protect your ears before there is an issue.
Go with custom molded there are a bunch of options out there. Mine block 25db but I can still hear engine and tire noise without issue. It does take a little getting used to as you retune your mind for the quieter environment but it will actually improve your ability to focus. Numerous studies bear this out
The other added bonus for me is that when I instruct I can have the communicator volume at reasonable levels which was never the case when using the regular ear pieces
