transmission fluid change intervals
Wondering when transmission fluid should be flushed and changed ? Porsche recommends 10 yrs but I find that an incredibly long period of time ... anyone else have experience in this ? Tks. Abe
If it shifts like butter, leave it alone. If you can't get into 1st from time to time or have a notchy 2nd when cold, an oil change will help. Btw, I have 3 liters of the manual transmission oil sitting in my garage I am selling for $60 if you need some
https://rennlist.com/forums/rennlist...arbox-oil.html
I do transmission fluid with every second brake fluid change. So, if brake fluid flush every two years (street driven), then transmission fluid at 4 years....regardless of mileage. If track driven, transmission fluid change yearly and fresh brake fluid before every track session, unless just a "leisurely" DE where not exceeding 7/10s. In that case, just change fluids as though it's a street car.
Some say "overkill"; I say really cheap insurance and priceless peace of mind.
BTW, the above applies to both manual gearbox cars as well as PDK-equipped vehicles. Don't confuse changing PDK transmission fluid with the clutch pack fluid...this helps explain: https://ecarguides.com/maintenance-g...911-2009-2016/
Had mine done at Hunter for under $200 at the time of cable and shifter replacement
Thank you- you and I are similar on prevention. I like to get ahead of the curve not behind it especially when dealing with these cars. Makes sense.
I follow the manual recommendations except for oil and filter changes which get done every couple of years - around 2k miles. I am willing to spare no expense for my classic cars but changing perfectly good fluids more often than necessary is a waste of money.
Captain Obvious
Super User
Super User
ronnie993tt (12-28-2021)
I would if I had tires that were on my Porsche for 10 yrs regardless of the tread. Your comment has inconsistent context.
strathconaman (01-13-2022)
Nothing wrong with inspecting the fluid too. If it looks good, leave it. Dirty, smelly, sparkly? Change it out if your ocd, take a sample and date it, with mileage.
