Border Crash
^wut
Stuck accelerator in a modern 2022 car?
Wouldn't it be of the "fly by wire" type?
Wouldn't just using the brake pedal for a few seconds cut out the throttle input?
I'm thinking more of a medical problem with the driver and the foot went full throttle.
Had a stuck throttle once....
1988 Nissan Pulsar SE
Was on the 401 close to my exit at Port Union rd...
Was a standard so took the car out of gear...and yes... revs shot up... key ignition off and coasted to a stop on the shoulder....
Didn't panic...
Kinda got myself settled down and wasn't sure what to expect... car started and never happened again..
Didn't panic...
The recall was for the pedal interfering with the interior panels when fully depressed and getting stuck.
In automatic cars, at least until automakers decided that PRNDL was passe, you could simply hit the shifter with the palm of your hand to knock it into neutral. This works as late as the 9x1 cars, but does it still work with the shaver in the 992 generation? Wouldn't be surprised if Bentley came up with their own "solution" that removed this useful failsafe measure for no good reason.
The bizarre part is how far the car flew in the air.
Ever see a flatbed on the side of the road tilted and think how much fun it would be to use it as a jump? Maybe that's what happened. Was she holding his beer? lol
Team Owner
https://www.google.com/search?q=driv...FFO1Rb5PU,st:0
Russian car crash videos are quite the YouTube rabbit hole. And Ring crashes/stupidity.
The following 2 users liked this post by maximusbibicus:
997turbocab (12-04-2023),
reacp911 (12-02-2023)
Any modern vehicle has far more braking power and accelerative power. That's why they stop in a shorter distance than it takes to accelerate to the same speed. If your car has a stuck or runaway throttle just apply full brakes and it will come to a stop and then put it in park or turn it off (once stationary). The parking or "emergency" brake is significantly less powerful than the primary braking system. Just think about it, it's always an additional tiny calliper, sets the rear calliper or is an in-rotor drum that's minuscule as opposed to all four multi-piston callipers on a Porsche or Bentley.
Bud Fox (12-03-2023)
