Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Rennlist Regional Forums (Regional Events, Discussions, Announcements, Etc.) > Rennlist Canada
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 01-15-2010, 12:36 AM   #1
MattAu
User
Default HELP locating an oil filter wrench
Anyone know where I can get one (it's for a 997) in Toronto? Better yet, anyone has one that I can borrow? I went to three Canadian Tires and bought two different types of wrenches and couldn't get my oil filter off. They also didn't have #7 cap wrench that according to Renntech forums seems to work.
I was so proud of myself for successfully changing the cabin filter and the air filter. I also drained all the oil out but now can't get the filter off. Needless to say, it's good that I have another car...
So if you can lend a hand, please let me know. And if not, please let me know what you think is my best option now:
1) Put the old oil back in and drive to an independent mechanic and ask them to loosen and hand tighten the oil filter for me and drive home and do the oil change myself.
2) Put new oil in and not replace the oil filter until Spring when I attend the Centennial course and replace the filter during class – my question is, would all the oil come out when I remove the filter forcing me to replenish the oil and therefore wasted the new oil that I am going to put in now?
MattAu is offline   Reply With Quote
Old 01-15-2010, 12:43 AM   #2
theiceman
theiceman's Avatar
Clive Young icemanxo theiceman911
how about grab it tighter ? is it a cartridge or a fully contained filter .. it should not be that tight .. I have grabbed em with massive lock wrenches before .. if it were an old car I could help you but I have no idea what we are dealing with ..
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
00 Audi A6
Gone but not forgotten
87 944S
" I'm not very smart but I know how to google "
theiceman is offline   Reply With Quote
Old 01-15-2010, 12:52 AM   #3
MattAu
User
It's a filter housing so I don't want to break it. I am heading down to the States tomorrow so I will see if I have better luck finding a wrench cap that is supposed to fit. On the Subaru, I was able to hand loosen the oil filter - which I understand is how it should be. The last oil change was done by Downtown Porsche. I bet you they torque it like they were torquing wheel bolts!
Old 01-15-2010, 12:59 AM   #4
theiceman
theiceman's Avatar
ah then you have a cartridge .. best be carefull there boy .. parts are spensive
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
00 Audi A6
87 944S
Old 01-15-2010, 04:09 AM   #5
scubadawg
User
I bought my oil filter wrench at a Mercedes dealership, it's the same size as Porsche paid abought $35.00 CAN for it. Porsche dealership does not sell them.
scubadawg is offline   Reply With Quote
Old 01-15-2010, 10:24 AM   #6
MattAu
User
That's good to know. Thanks for the tip scubadawg. Any idea what model and year I should ask for
Old 01-15-2010, 11:05 AM   #7
PbPedis
PbPedis's Avatar
When I asked in the past, they told me to get it from Snap-On tools. I ended up getting mine at Suncoast but that won't help you since you need it ASAP.
PbPedis is online now   Reply With Quote
Old 01-15-2010, 12:50 PM   #8
Torontoworker
Super User
Torontoworker's Avatar
I don't have the service page with me but I think the filter housing should be hand tight - 19 ft/lbs.
Your looking for a product that is 74.4mm, and has 14 points.
Torontoworker is offline   Reply With Quote
Old 01-15-2010, 01:05 PM   #9
scubadawg
User
Mercedes Part Number: 103-589-02-09-00 Socket Wrench $32.30
Old 01-15-2010, 02:53 PM   #10
jasonintoronto
User
jasonintoronto's Avatar
Quote:
nice work! forums saves the day.
jasonintoronto is offline   Reply With Quote
Old 01-16-2010, 12:12 AM   #11
MattAu
User
So I bought the MB wrench, thanks to scubadawg!
I got a call back from Pfaff - they told me that they can order it and it will cost $52 + taxes
Downtown Porsche told me that it's not available but I should be able to find it at Canadian Tire or NAPA
The Porsche dealer in Buffalo (where I am now) told me that they don't sell it but I can get it online if I google the words "Florida" "Porsche" "Oil Filter" "Wrench". I assume they meant Suncoast
So when I get home on Sunday, I will try the MB wrench, hopefully it works. BTW it takes a 22mm socket (I think the Porsche one takes 27mm)
I will post back with update after I try the MB wrench
Old 01-16-2010, 03:06 AM   #12
scubadawg
User
I did 2 oil changes with the MB oil wrench, This last oil change I decided to switch oil brand from using Mobil 1 - 0-40, trying out Motul X-CESS 5-40 this year. Car is park until middle of April.
When I did the oil changes, I switched out my drain plug, and used a magnetic drain plug, too bad the Housing wasn't metal, then I would use a filtermag, like I have on my SUV. I can't justify the cost of spending $150.00 to put a spin on filter adapter, when I only do 1 oil change a year, (drive only about 5-7K per year)
Old 01-17-2010, 09:07 PM   #13
MattAu
User
Just finished changing the oil. With the use of the MB wrench and my newly acquired 25" breaker bar, the filer housing came loose very easily. In my moment of excitment, I forgot to lube the new gasket after putting it on. Keeping my fingers crossed that it won't leak.
Thanks again to everyone for the help. It was $36.35 well spent.
Old 01-18-2010, 08:27 PM   #14
Turbodan
Turbodan's Avatar
the lube is not just to prevent leakage but also to ensure an easy removal the next time...otherwise it can get caked on and then clean up is required before replacing. I would remove the filter now and lube it up, and if the gasket is damaged then get a new filter. don't ever forget LUBE.
good thing is you probably will only make this mistake once! good luck!
Danny
96 993tt black/ black Gemballa suspension, techart brake ducts, turbo s oil cooler, 19" HRE's,
86 951 white/black cupcar suspension, big reds, half cage
87 951 white/black, M30, max951 chip,gone after 12 years ownership, and now missed
see my video Sunday Drive *
http://www.youtube.com/watch?v=hJGm2JhSqwk
Turbodan is offline   Reply With Quote
Old 01-18-2010, 09:12 PM   #15
MattAu
User
If I were to remove the filter housing now to lube the gasket, wouldn't the oil start dripping out from the engine? In other words, if I am really careful with removing the filter housing, will I have to refill the engine with oil?
Tags
00, 02, 09, 103, 2005, 589, 993, 996, 997, cayenne, change, filter, mb, oil, porsche, removal, tool, turbo, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
