Garage build advice?
Insulate to the max and don't forget the floor.
Although a heated floor is neat, I think it only works if you are happy with the constant temperature it is set at.
I keep my garage at 7 degrees and my 60,000 btu gas heater heats it up real fast to 20 degrees so it is comfortable.
Good idea, JP.
Patrick, it will be full of my collection, day one, sorry!
I'll report back if this moves forward, thanks for the great ideas guys!
RK
RK
Garage journal dot Com has a ton of info, from small sheds to multi Bay setups. Check them out.
Peter
Peter
I have a small garage (city house) but I wanted to be able to wash the car in winter. I have a heated, epoxy floor with a centre drain (also consider a trench drain at the door if there's any possibility of water flowing into the garage because of grading). They used the drywall that they put in showers (I can't remember what it's called) followed by a waterproof membrane and tiles - effectively making it into a large shower. The garage door should be insulated and the hardware needs to be powder coated to prevent rusting. T5 lights all around with shields. Hot and cold water.
We need photo's. I love spending vicariously.
lots of outlet
Insulate the thing to the max
insulated door
I built my air compressor into the attic. way quieter.
cable/bell/cad 5/alarm/stereo/security to keep rennlister's out
bright surgical lighting- a work space can never be too bright. Look into LED's. some Florescent don't like to start in the cold.
If you are really going to work there in the winter. Heat
hot and cold water/floor drain
If you are bringing power from the house leave an extra conduit for something you've forgotten
lots of outlet
insulated door
Too bad you have a max inside ht limit.
I built mine 10'-6" inside so I can easily use 4 post lift and work under cars, without crouching.
Porcelain 8"x 8" tiles on floor and 3' up the walls for easy cleaning.
Beer fridge is also mandatory.
Good luck
Good luck
Yeah, but higher would obscure west view from house. I don't really need a lift, my hardcore race/rally car building days are over. If I go racing again, I'll outsource any serious development work.
All great ideas above, thanks guys! I will post pics if we move forward.
RK
RK
Here's what I did.
I have retractable reels for electrical & air in the ceiling. (princess auto)
Extra outlets on the wall.
Ran switched hydro in the ceiling for lighting.
In ceiling speakers for the stereo.
Cable for the TV.
Two 110 cfm bathroom exhaust fans (it's the winter cigar lounge after all)
Since your building new, have the door guys install the door rails & spring right to the ceiling and install the Liftmaster 8500 door lifts for best clearance.
Come spring, it's the overhead furnace, overhead storage, lift & Racedeck.
Cable for the TV.
....oh ya love the Porsche flag on the ceiling... . What kind of hoist /system do you use for the canoe?
Most useful thing I installed in my garage was a computer above the work station. There are you-tube videos for everything you may want to do on your cars. sink it in the wall before you build.
with the garage doors install a jack drive lift it is mounted on the shaft of the spring bar nothing hanging down from the ceiling and use high lift tracks so the door tracks to the ceiling.
Have a 4.5" slope from high to low on a 24' floor make sure it is compacted so there is no settlement.
i would have a 4' foundation and have a shelf to hold the floor onto the foundation throw in the rebar and pour a min 6" floor. use bellagio fluorescent bar as they seem to work pretty good in cool temperature.
do not forget your building permit
