Anyone DE'ing this weekend?
Old 09-16-2015, 11:28 PM
vern1
vern1's Avatar
Default Anyone DE'ing this weekend?
Am hoping for no rain!!
Old 09-17-2015, 11:42 AM
vern1
vern1's Avatar
No one?? It will be lonely but guess I'll get lots of track time....
Old 09-17-2015, 12:30 PM
gbuff
gbuff's Avatar
Yes, but not at Mosport.....but I WAS there y-day and you couldn't have asked for a better day--perfect weather, no incidents that I know of and TWO personal best laps on the day! Won't be forgotten any time soon
Wishing you the same--
Gary
Old 09-17-2015, 12:56 PM
Quinlan
Quinlan's Avatar
I'll be there, along with my son, daughter and son-in-law! So there's four more for you
Old 09-17-2015, 01:48 PM
911 Rod
911 Rod's Avatar
I'll be there.
It's going to be a great weekend!
Old 09-17-2015, 02:05 PM
crooster
crooster's Avatar
I'll be there.
Old 09-17-2015, 02:20 PM
pontifex4
pontifex4's Avatar
I wish I were! Sadly, I'm stuck on the wrong side of the country for it, thanks to politics.
Have fun, guys.
Old 09-17-2015, 02:47 PM
PPo
PPo's Avatar
Embrace the rain if it does... Best time to learn to drive IMHO!
Old 09-17-2015, 03:27 PM
Turbodan
Turbodan's Avatar
I have a pretty full weekend so won't be there. Have a blast!
Old 09-17-2015, 05:34 PM
vern1
vern1's Avatar
I have never been on the track in the rain. Have to admit, those walls scare me plenty when its dry so if it rains, it should be "interesting"
And my seats will get wet
Old 09-17-2015, 05:48 PM
Turbodan
Turbodan's Avatar
or brown
Old 09-18-2015, 09:50 AM
Jonathon Rolstin
Jonathon Rolstin's Avatar
lol... Wish I was there as well, I cancelled... but who knows maybe I got charged again and I should just showup... Would be hard to though since I hopped in my car the other day and the brake pedal went to the floor!.... fixing that this wkd..
Old 09-18-2015, 11:42 AM
PPo
PPo's Avatar
Learning the wet line is an important skill.
Learning to "watch" or "read" for traction while keeping your head up is important. Don't do anything when crossing on the shiny parts. Maintain throttle and keep steering as straight as possible when crossing shiny parts. If you can't see the shiny parts, assume that the standard line in the corner is the shiny part. General rule for the wet line is: inside-outside-inside; the opposite of the dry line. Take it slow in the wet line, and gently increase you speed as you get used to the wet line and the traction.
Once you learn to read traction, you will be surprised how fast you can drive on a wet track without having to be the re-incarnated Colin McRae. This totally transfers to dry, but is not taught because it's too much for early drivers to handle. Rain slows everything down and teaches you to read the track for traction by eyes, and bum. Best skill to learn!!
Just take it easy, don't get cocky, and slow down on the straights... most wet accidents happen because you carried too much speed into the corner, or got on the throttle to aggressively and early on exit. There is no prize for winning a DE. Stay slow well before the corner, and work on building your speed. Keep distance from other cars.
Relax your grip!!! Most people tighten up in the rain. You almost have to be more relaxed in the rain. If your grip on the wheel is too tight you will crash... let the car breath and guide it through the wet.
You will learn more in one session of a wet track than a whole weekend on dry!
Old 09-18-2015, 03:17 PM
gbuff
gbuff's Avatar
I've found that Mosport is actually pretty grippy in the rain now with the improvements they've made, so that'll help some.....thankfully it's not Mid-Ohio which is a death trap in the wet.
Gary
Old 09-18-2015, 04:03 PM
jumper5836
jumper5836's Avatar
Gary
Mid Ohio has lot of grip off the dry line. Also much better track for the rain because it is not a high speed track like Mosport. I enjoy Mid Ohio in the wet, with the slower speeds and even enjoy driving the dry line and drifting the car through out the tight corners because of the slower speeds. I would never attempt it at Mosport even at reduced speed the corners are still way to fast for cornering grip and not enough track to allow it to slide. If your on the wet line there is absolutely no track left for any catching it. Which is why I usually keep unloaded wheels on the dry line and don't use the standard wet line that is taught.
Quick Reply: Anyone DE'ing this weekend?
