Go carting for kids.
Captain Obvious
Super User
Super User
It's an Arrow AX-9 chassis made in '05, the enigine is a regular Honda GX200. Can't post pics anymore on RL but here is the Kijiji add to give you an idea. The seller put the engine back in the kart so I can hear it running.
http://www.kijiji.ca/v-cars-other/ki...ationFlag=true
Depending what you paid for it, it looks like a good deal, with all the spares and computer (Alphano?), which on its own is worth several hundred dollars if it works properly!
Have fun!
Captain Obvious
Super User
Super User
Yes it's a full size one. It was $700 for everything. We'll see if I can set it up for the little guy. I know the smaller ones are better suited at his age but then a year or two from now, he will out grow it. If it can't be set up for him, I'll figure something out then. The computer is working as far as I can tell. It powers up and reads the RPM, shows the last lap times the seller had. Now that the engine is sorted out, going to see how much the pedals and seat can be adjusted.
Captain Obvious
Super User
Super User
Slight twist in the plan. Finally read the rulebook and the current engine (200cc) is too big for his class (needs to be a 160cc Honda). BUT as luck would have it, last summer at a neighbour's garage sale, I bought a pressure washer that needs the water pump to be re sealed, BUT by luck, turns out the engine is a Honda GX160, exactly what the Waterloo Regional Kart Club rulebook requires. Nice to be lucky every now and then. Just need to remove the RPM governer, make a few small adjustments to the throttle linkage, install a crank vent line for the fuel pump and it's ready to go. Mark Too sent me his contact and will be sending in the membership paperwork to the club tonight. The little guy took the kart out for a spin on the weekends in a parking lot behind an industrial complex and the freshly cleaned carburetor makes the engine run really nice. Too bad he won't be using it for at least 4 years. He will have to start with the 160cc engine, stock muffler and a 0.350" restrictor plate. Told him he needs to learn how to properly drive before going fast. I think he understood.
Warning - this is a slippery slope and soon it will consume all your time and money. But you will have a great time with your son, so what could be better!
These days I spend more time on my karts and kart engines than my Porsches (mostly because in the winter I can bring kart engines into the house from my unheated garage...). I have been going a bit crazy for karts and engines from the '90s, simple air-cooled thoroughbreds that can be had for peanuts and are great fun for lapping. This is my Tony Kart with a Vortex 100cc JICA engine....
I also have a Kali Kart and 9 other engines from a Yamaha KT100 to an Ital Sis 100cc 20,000 rpm rotary valve ICA, all either running or on the kitchen table
As I said, a bit crazy...
Captain Obvious
Super User
Super User
