928 Tech/dyno day-CT.
Here is the information :
David Lloyd is planning the event for April 24th, 2004.
DATE: Saturday, April 24, 2004
PLACE: Musante Motorsports
South Windsor, CT
www.musantemotorsports.com (for directions)
TIME: 9 till Noon at MM, then to the dyno shop till around 4
COST: tba, but probably a nominal charge to cover food/t-shirts or
whatever, then $75 per car for 3 pulls on the dyno, printed results of
HP,
torque and A/F ratio.
Anyone interested should contact David at David@MusanteMotorsports.com
Contact Dave ASAP if you are going or want a dyno pull.
South Windsor, CT
HP,
Owns the Streets
Needs Camber
Needs Camber
Hi Flott Leben,
Just over 2 hours up Rt 84 to Musante.
Also depending on how quickly the I-95 toasted bridgeway
gets fixed.
I prefer I-84 to Merritt. Nice and fast with couple of
good curves and nice uphills designed for the big V8.
Beware of the state poopers on 84.
Ernest (NYC)
gets fixed.
Ernest (NYC)
