Supercharged: 513 SAE RWHP...
11 psi, stock block, Ott x-pipe, dual mandrel 2.5" exhaust.
The run is what it is, period. Keep reading though if you want to hear post-run observations/critiques/excuses. I know they'll sound like excuses, but nonetheless, I'm trying to be objective.
I am a bit disappointed as I was expecting more as my calcs said I should make around 530 rwhp with 11 psi of boost at 6400 RPM with my Ott x-pipe and new dual mandrel 2.5" exhaust. What (..possibly) happened?
The car was dyno-ed at a Porsche dealership in conjunction with the Chicago PCA Club, lots of nice cars there! The next highest dyno run was by a By-Design modified 996 which put out 289 rwhp. Needless to say, the other Porsche owners were very impressed by the 928's numbers.
Well, when I got home I looked at the chart again after some of the shock wore off, the first thing I noticed was that the run ended at 5900 RPM. Of course, that's my fault, but how could I do such a stupid thing? Well, I failed to mention to the operator who drove the car on the dyno to take it to 6500 RPM; he was evidently being conservative and cut the run off before the perceived 6000 RPM redline indicated on the tach. Doh!; my fault for not communicating.
The last item is that the air/fuel ratio was rich as it stayed at 11.5 for most of the run, and it popped up to 12.1 right at the very end; my fault again for not tuning better.
With that said, my/our goal is to optimize the car for 11 psi of boost, nothing more, as that boost level is pretty much the max for a 10:1 cr engine. So, I'm thinking there will be one more dyno run this year before winter puts the cars up for hibernation.
First and foremost, we've got to get a better fuel curve and get it as close as possible to 12.5 throughout the entire run. Secondly, take the engine to 6500 RPM! That shouldn't be a problem as the local dyno lets the owners operate their car during the run, and make no mistake, I will be bouncing it off the rev limiter to end the run!
The results, for better or worse, will be posted for all to see/critique.
Lag,
It appears, to my feeble brain, that you have NOTHING to make excuses for. Those are impressive numbers by anyone's standards.
I should send the dyno operator a thank you note for pulling out of the gas so I can keep the top honors for just a bit longer.
Good job!! I wish I could have been there to see the faces of the 911 guys when the numbers came up. I wonder if anyone from that group posts to the 911/993 boards? It would be interesting to listen in on what they have to say about your numbers.
Range Master
Pepsie Lite
Pepsie Lite
Hoo Ha!!!!!
Bring it on TIM, my wrenches are at the ready!!!!!!!!!!!!!!
BTW, Exactly what do you call your kit, just so I am using an approved reference in my signature.................
G
G
Murph and Tim,
Just curious about Murph's car vs the kit. I think I remember reading that the kit is 7 psi, right? Is there any reason for the kit not to be at 11psi? Significant mods required? Just a conservative 'safety' factor?
thanks and congrats to both of you,
Jim
Jim
Range Master
Pepsie Lite
Pepsie Lite
"Murph" and Tim are the same person, (Tim Murphy) You prolly ment to adress Lag.......
Good question............bet Tim has an informative answer..............
Sorry?!?!?
Jeez, Lags!
You got nothing to be "sorry" for! Awesome numbers. Period.
Not too many cars around you can't spank.
And after tweaking the a/f ratio, you'll have better numbers!
Curious: does the dual 2.5" flow enough or would you be better off with dual 3"?
Congrats!
Congrats!
Originally posted by jim morehouse
Murph and Tim,
Jim
Murph and Tim,
Jim
Can you PM or email me about those Cometic gaskets Tim? If there is any lead time involved, I need to make sure they are ready when I bolt everything back together.
Can you go into more detail on the issue you note above?
Thanks!
Thanks!
Excellent job, nice horsepower & torque. How many miles have you driven on this configuration? Are you pushing the car at all? This sounds like the hot ticket! A little to much boost for me but impressive none the less.
Originally posted by sweanders
Btw, isn't 289hp pretty low for a 996? Did they all stop at 6000 rpm's?
Originally posted by DerSchlechtSpecht
Wow, I should definatly get a 928.
There are two guys that were there who told me they are now actively looking for 928s, and asked if I knew of any for sale.
There was also some variation of 911 there with a supercharger kit on it. (Sorry, but I really don't know the difference in "911" model variations.) He made a good bit less than he was expecting to based on the claims of that kit's manufacturer, and nowhere near even 300rwhp. He definitely wasn't happy, and there was definitely a phone call to that kit supplier planned for first thing this morning.
