View Poll Results: Interested?
32V cam timing tool
79.31%
16V/32V conversion
20.69%
Voters: 29. You may not vote on this poll
32V Cam Timing Tool & 16V/32V Conv 'Group Buy' #2
Old 01-22-2005, 09:13 PM
PorKen
Inventor
PorKen's Avatar
Default 32V Cam Timing Tool & 16V/32V Conv 'Group Buy' #2
Old 01-22-2005, 10:11 PM
PorKen
Inventor
PorKen's Avatar
Default PDF manuals
32V cam timing tool: (32VCamSetup1_0.pdf 380KB)
16V/32V conversion: (16V32VGearSetup2_0.pdf 513KB)
Old 01-23-2005, 02:51 AM
SharkSkin
SharkSkin's Avatar
Oops... I voted before reading the whole thing. Randy, can you retract my vote? I already have one on order.
Old 01-23-2005, 04:36 AM
PorKen
Inventor
PorKen's Avatar
Dave,
You'll just have to get another 16V to go with your second order.
Old 01-23-2005, 04:48 AM
SharkSkin
SharkSkin's Avatar
Dang, you're right!
Old 01-23-2005, 09:43 PM
H2
H2's Avatar
I just PayPal-ed you $64 for a 32V kit. Thanks!
Harvey
Old 01-24-2005, 08:26 PM
H2
H2's Avatar
Porken,
Does it look like you'll be able to make a second run of 32V sets? Or is it too early to tell?
Harvey
Old 01-24-2005, 08:52 PM
Vlocity
Vlocity's Avatar
I hate to admit my ignorance, but how do we change the index of the cam say by a 1/2 tooth. I'm interested in the tool as part of this process, by passenger side bank is always off just a bit.
Regards,
Ken
Old 01-24-2005, 09:31 PM
PorKen
Inventor
PorKen's Avatar
Harvey,
I expect that after the first group recieves the tool later this week, the positive(!) feedback will generate a flood of orders.
Ken,
The WSM procedure for the 32V involves using a dial indicator, and measuring the amount of lift on the face of a lifter, when the engine is at 20 degrees past cylinder #6 TDC (=#1 BDC). If the lift is not what is stated for the particular year/cam, then the cam bolt is loosened, and the cam is rotated until the measurement is obtained.
The factory specs a slightly different value for the right (US passenger) cam, to allow for the envisioned advance caused by expansion of the engine when the engine is at operating temperature.
My tool indicates the center of the cam woodruff key, which corresponds to the notch on the 16V, non-adjustable gears, and indicates TDC for cylinder #1. It also shows plus or minus 6 degrees in 2 degree increments.
Ideally you would set your cams using the WSM method, then, using my pointer, record the degree measurement for each bank. From there you can easily play with the advance, or retard, and return to stock, without having to remove the cam covers.
Generally speaking, advancing will give you more torque, lower in rpms, and retarding will raise horsepower, higher in rpms. Raising one, however, will reduce the other.
Old 01-25-2005, 04:11 PM
PorKen
Inventor
PorKen's Avatar
16V conversion manual version 2.0 online, above.
Old 01-26-2005, 11:34 PM
FlyingDog
FlyingDog's Avatar
Mine just arrived today... they are NICE!
The stainless is thicker than I thought it'd be. You'd have to try to knock them out of calibration.
Old 01-27-2005, 04:49 AM
SharkSkin
SharkSkin's Avatar
Ken, can you be more specific about the 20mm spec? It's not clear which surface of the ring should be 20mm from which surface of the pointer.
Old 01-27-2005, 01:50 PM
PorKen
Inventor
PorKen's Avatar
Matt,
That was quick. Glad you like the kit!
Dave,
I thought that might be unclear. I will add additional text to the manuals.
The inside faces should be 20mm (+-0.25mm) apart.
I'm still waiting for pics for the 32V manual. I may have to buy a 32V car for myself...for research!
Old 01-27-2005, 07:51 PM
PorKen
Inventor
PorKen's Avatar
I just found out you may not be able to use the pointers for '87-up. The hall effect wheel behind the right cam gear is in the way!
They work great for the 16V conversions, and should work for '85, '86.
As previously stated, I will refund those that cannot use them, after you ship them back to me. Sorry to inconvience.
Please email me if returning.
Old 01-27-2005, 09:42 PM
Shane
Sharkaholic
Shane's Avatar
Cool finally something hits the market that ISN'T for '87 and up only! Way to go Ken!! Keep 'em coming!
Quick Reply: 32V Cam Timing Tool & 16V/32V Conv 'Group Buy' #2
