32 Valve Timing Indicator Kits
Old 03-08-2005, 04:20 AM
PorKen
Inventor
PorKen's Avatar
Lightbulb 32 Valve Timing Indicator Kits
Zweiunddreißigventilsteuerzeitenanzeigersätze
~Laser Cut Stainless Steel Quick Release Tool
~Laser Cut Stainless Steel Clamp Rings
~Stainless Steel Allen Head Bolts
~Indicator (spare included)
~Adjustment Spacer
~Printed Manual
~Easier cam gear swaps!
~Check your valve timing at each belt change or retension!**
~Quickly adjust your valve timing for more torque, or horsepower!**
**Initial setup should be performed using a dial indicator as shown in the workshop manual.
PorKen
Inventor
PorKen's Avatar
Default PDF Manual
(32VCamSetup1_0.pdf 380KB)
Old 03-08-2005, 08:12 AM
Lagavulin
Lagavulin's Avatar
Looks good, money sent!
Originally Posted by PorKen
PayPal or info email address: cams AT mrtubby DOT net
Since it's a little confusing, I would change your listed email address ' cams AT mrtubby DOT net' which is a non-standard format, to the real thing (..cams@mrtubby.net) as you have it listed on page 1 of your excellent manual.
Old 03-08-2005, 08:43 AM
Jim R.
Jim R.'s Avatar
Nice work!
Another set purchased-paypal sent
Jim R.
Old 03-08-2005, 12:43 PM
PorKen
Inventor
PorKen's Avatar
Thanks, y'all!
I will change my email, I was paranoid about spam-bots.
BTW, writing manuals (copywriting as they say in the trade ) is a beeyatch, the 16V manual took quite a while: (16V32VGearSetup2_0.pdf 513KB)
I will be mostly away from my computer for the next few days, so please be patient if I don't respond to PM's right away!
Old 03-08-2005, 12:57 PM
Glen McCartney
Glen McCartney's Avatar
I'm in!
I'm sending PayPal as soon as I get off the Rennlist site!
Old 03-08-2005, 05:31 PM
Benton
Benton's Avatar
Awesome, so these are accurate for sure? Once I hear back, I will be sending my money!
Old 03-08-2005, 05:54 PM
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
So...does the ** part mean that someone doing a top-end rebuild (cough cough) still needs to use the factory gauges to time the valves? Probably an obvious answer, but I still wanted to ask.
Old 03-08-2005, 08:58 PM
PorKen
Inventor
PorKen's Avatar
Mark,
All 20 in this batch were bent correctly this time. It cost more, but the shop spent more time on setup, and I added features to help them do it right.
Dave,
I would use the factory method, for a big job like that, mostly for a sanity check, in case the cams were not ground perfectly, in relation to the woodruff key. From there you could go ahead and play around with timing with the Pointer.
The dial indicator method is really not that difficult, after you figure out how to get a consistent zero.
928 Specialists lists the factory adapter tool (000.721.923.20 - which you screw into your Harbor Freight dial indicator), for only $7! Or it's easy enough to make one.
Tool 9232
Dial Indicator Extension
Old 03-09-2005, 12:20 AM
jheis
jheis's Avatar
Ken:
What's the price on the 32V cam sprocket to 16V kit?
James
Old 03-09-2005, 12:29 AM
GoRideSno
GoRideSno's Avatar
WAAAAY Cool!
Gotta get some money into my pay pal account.
Andy K
Old 03-09-2005, 11:59 AM
PorKen
Inventor
PorKen's Avatar
James,
The 16V Adjustable Gear Conversion is $ (includes shipping/PayPal fees).
As of this writing, I have only enough parts to make (3) of them, and I don't plan on having any more of the setup tools cut/bent anytime soon.
Old 03-09-2005, 05:30 PM
SharkSkin
SharkSkin's Avatar
So... Should I be checking my mailbox anytime soon?
Old 03-09-2005, 05:47 PM
heinrich
928 Collector
heinrich's Avatar
Yes, for those of us that returned ours ... que paso?
Old 03-09-2005, 10:14 PM
PorKen
Inventor
PorKen's Avatar
Dave,
Sorry, I've been ******* you! (Well, you would have had a set a long time ago, if the machine shop didn't go wild on one of the hubs...)
Anyhu, your kit is ready to go - well, as soon as I have the new hubs machined.
Heinrich,
I finally got your return - it went to the wrong address! You have already been included in the sold tally above.
Quick Reply: 32 Valve Timing Indicator Kits
