Where can I get this part?
Old 03-17-2005, 06:03 PM
jmporsche944
jmporsche944's Avatar
Default Where can I get this part?
Heres a picture of my engine when it was together. When I was replacing the vacume lines I snapped the line and plastic connector off this thing by mistake. I have no idea what it is or where I can get it. Any help is appreciated. (I drew a red arrow to the part. Its a blue cap thing with a small line that connects to the center of it.
Old 03-17-2005, 06:11 PM
944_S_TYPE
944_S_TYPE's Avatar
I think it is a vaccum sys check valve... Anyone ?
Old 03-17-2005, 06:14 PM
FletchDM
FletchDM's Avatar
That's the brake booster check valve. Mine was broken when I got the car, resulting in an unstable idle (vacuum leaks can do that). You can get one from Pelican, Paragon, etc. for about $15. THe black & blue thing above it is also a chack valve, I think, but I'm not sure of the part #.
-David
Old 03-17-2005, 06:48 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
On the 951, that check valve is used for the climate control vacuum system
Old 03-17-2005, 09:03 PM
jmporsche944
Will the car run without this? I plan on replacing it but I just want to start the car up and see if the timing belt/balance belt job I just did went smoothly.
Old 03-17-2005, 10:18 PM
FletchDM
FletchDM's Avatar
It'll run... but the idle will be a little rough and will probably hunt a bit up and down (mine did, anyway).
-David
Old 03-17-2005, 10:25 PM
Gator_86_951
Spell Checker
Gator_86_951's Avatar
hosrom didn't you buy one of those from the dealer. that is what i remember.
Old 03-21-2005, 06:13 PM
michaelathome
michaelathome's Avatar
Anyone have a write up on replacing this piece? Nothing found in threads or at clarks-garage.
I haven't checked Haynes yet.
Michael
Old 03-22-2005, 01:29 AM
camelot
camelot's Avatar
I've been having good luck with 9440nline.com. They are very good and know their parts. Check out their web site, you'll probably see the part. Oh btw I got that na running I was talking about at the gtg in nj. It was good to meet you.
Old 03-22-2005, 03:05 AM
hosrom_951
hosrom_951's Avatar
Sorry for the late response; Yes, i did purchase 3 from the dealer. one failed (original) and casued a humming noise from the engine bay. The other two i got for a replacement and one extra as a spare.
Old 03-23-2005, 02:43 PM
Dilberto
Dilberto's Avatar
I have an extra one if you want it. Reply with mailing address.
Always willing to help out another Porsche owner-
Zach
Quick Reply: Where can I get this part?
