Has anyone done this PSE mod on a 997?
Old 08-16-2005, 12:09 PM
1080iAddict
1080iAddict's Avatar
Default Has anyone done this PSE mod on a 997?
Check out this thread:
http://www.renntech.org/forums/index.php?showtopic=2470
Anyone know if this works on a 997 for the PSE cut-off?
Old 08-16-2005, 01:34 PM
DD694
DD694's Avatar
The 997 PSE uses NOT the speedometer signal input, but an input from the engine DME. I am not sure if this relay is even present in a 997/997S.
Old 08-16-2005, 01:38 PM
1080iAddict
damn. It looked like a great mod!
Old 08-16-2005, 02:06 PM
MJones
MJones's Avatar
Want loud all the time?
The answer is in this thread:
PSE Loudness Mod
Vroom vroom
Old 08-16-2005, 02:25 PM
Lemur
Lemur's Avatar
Actually, There is an even easier way. Simply disconnect the electrical connection as shown below and you will have the desired effect. It took me more time to open and close the hatch than to complete the "modification".
PM me if you need more help.
Regards,
DAB
https://rennlist.com/forums/attachme...hmentid=&stc=1
Old 08-16-2005, 02:35 PM
1080iAddict
PSE Loudness Mod
Vroom vroom
Thanks MJones. I read that entire thread before. I dont want loud all the time, but instead wish to mute same through the Sport button in the same way it operates now (albiet without the automatic cutoff). That is why the relay mod I posted is so cool - it simply eliminates the cutoff while all other operations remain the same.
Apparently, however, that mod is not available for the 997.
Old 08-16-2005, 02:52 PM
1080iAddict
DAB - sent you a PM....
-A
Old 08-17-2005, 03:41 PM
NoSubEDU
NoSubEDU's Avatar
Regards,
DAB
NO CEL's or indicators inside the car? Looks like a switch, and I would think that the ecm would know about it??
Regardless, good find!
Old 08-17-2005, 04:46 PM
Ray G
Ray G's Avatar
Regards,
DAB
I've done this - it works great and takes all of 2 seconds to do!
Old 08-22-2005, 06:53 PM
bluelines
bluelines's Avatar
Regards,
DAB
Ok, will this mod ONLY remove the cut-off but you are still able to control ON/OFF with the Sport button?
Old 08-23-2005, 01:53 AM
jcnesq
Miserable Old Bastard
jcnesq's Avatar
I'm sure that mod means PSE on all the time, no ability to control it from the Sport button.
Although I would have liked to install the controls, I didn't, because I could not find any way to disable only the cutout between 30-50mph (or something like that). So I'm on all the time, just like you would be with the easy mod above.
Old 08-23-2005, 02:30 AM
bluelines
bluelines's Avatar
I have already done the even easier mod by removing the vacum hose from the controller, which leaves PSE on all the time. Awesome, but I still like to control ON/OFF. Period.
Guess I just have to try
Old 08-23-2005, 11:40 AM
SamG
SamG's Avatar
Jim, do you still have your stock mufflers? Am curious if they look like they can be modified like the ones in the "No more PSE?" thread.
Old 08-23-2005, 12:23 PM
bluelines
bluelines's Avatar
And of course PSE is on all the time... same effect as removing the vacum hose. Guess hacking the DME is only alternative.
Old 08-25-2005, 05:20 PM
AeroSmith
AeroSmith's Avatar
Question
So what's the scoop? Can this be done on a 997 PSE????
Quick Reply: Has anyone done this PSE mod on a 997?
