996 Forum 1999-2005
Make ur own Fabspeed box for $13.66 &
Old 01-15-2002, 02:01 PM
  #31
MKW
MKW's Avatar
Post
From my reviews, the engineering for the '02 was to get significant performance gains at 3000-5000 rpm where you can really feel it. The air box mod only helps above 5500 rpm- you won't feel that in every day driving. We should get someone with an'02 to do this mod before / after !If I had an '02 , you bet it would be the first thing I would try after break in. For $200 bucks after spending $85K , it would be worth it for me. Chevy Corvette guys all get dyno proved 15-20 hp on an already "optimized" 350 and 405 hp engines with similar mods. Dodge added " smooth tubes and K&N " on their ACR model ( after aftermarket had done it for years ) and published an extra 10 hp for that factory mod. Chevy took off their MAF screen on '02 Z06 , finally admitting it was mainly there for catching stuff, not smoothing flow.
Old 01-15-2002, 02:06 PM
  #32
ben in lj
ben in lj's Avatar
Post
"Dodge added " smooth tubes and K&N " on their ACR model ( after aftermarket had done it for years ) and published an extra 10 hp for that factory mod. Chevy took off their MAF screen on '02 Z06 , finally admitting it was mainly there for catching stuff, not smoothing flow."
Sure, and using the % of total pre-hp that the extra 10 hp represented on that ACR (not to mention the MUCH flatter torque curve on V8 and V10s), apply that % to the 300 hp Carerra and tell me what you get in terms of hp increase (btw, torque - NOT hp - is what causes the performance increases you are testing for). Ditto on the Z06. Further, how much of a decrease in times do you suppose that infintismal 10 hp as a % of total hp represented? NO WAY, NO HOW was it .20 - much less the .4 you posted.
Old 01-15-2002, 03:09 PM
  #33
MKW
MKW's Avatar
Post
Hey people, do what I did 3 months ago, before the Airetek , RM , and Fabspeed mods hit the market : I used a 50 cent high temp plastic cap plug ,Niagra ( Erie , Pennsylvania) # 273-1P , that has a 1 15/16 " flange lip and inside diameter 1 3/4" and 7/16" deep that is a PERFECT fit into the air muffler box " neck", so you just put the secondary air bridge back on - completely eliminates the muffler- elegant solution- no " drain plug" / sawing for 13 bucks. Great sound. Still uses the corrigated OEM bridge and the eddy flow of the secondary bridge still exists , though.
I would still do the Fabspeed , after comparing the two methods.
Old 01-15-2002, 03:36 PM
  #34
MKW
MKW's Avatar
Post
Niagaraplastics.com is their website.
Old 01-24-2002, 09:50 PM
  #35
ben in lj
ben in lj's Avatar
Post
MKW, your solution arrived today. It sure is even easier than mine! The only thing I might say is that both you and Joe leave in the top half of the muffler box which a) restricts air flow, and b) is a very rough surface owing to the walls which don't encourage the smooth flow like a) no top half or b) the smooth bottom half muffler case provided in the OEM box. All in all though, I'd say you accomplished all Joe did for free - they sent mine via a free sample with no shipping, etc.
Old 01-24-2002, 11:28 PM
  #36
MKW
MKW's Avatar
Post
LOL ! I can see it now : hundreds of requests for that "free" plug !
Old 05-05-2002, 04:28 PM
  #37
Kostas Vassiliadis
Kostas Vassiliadis's Avatar
Question
can you please tell me where to find info on your mod??
regards <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Old 05-05-2002, 05:07 PM
  #38
MKW
MKW's Avatar
Post
Wow, dredging up nostalgia ! Last week, I retested my run from 1/13/02 post. "Flying" 60-100 mph in same place/ conditions ( but full tank of gas ) was 6.57 seconds. So the Fabspeed improvement has held after 6 months and 3000 miles w/o evidence of negative ECM relearning.
Old 08-30-2003, 11:55 AM
  #39
silver996
silver996's Avatar
Ben in LJ,
I was curious to see your airbox setup, but the link to funcars doesn't work anymore. Can you update the link for me please?
Thanks
David
Old 08-30-2003, 08:12 PM
  #40
Scouser
Scouser's Avatar
But I can't seem to get to this URL. Even wgen I log on to funcarsonline I can't find the thread in any search. Any help appreciated.
I gotta vouche for everything the man from Fabspeed (above) says. Gaaaagious music out the rear end of my porsches tuchas and I get a great kick in the pants every time I blip into 3rd at about 5000 rpm.
Berny
Old 08-30-2003, 10:46 PM
  #41
ben in lj
ben in lj's Avatar
sorry, but i don't have any of those pictures saved. that said, i am supercharging the car in a couple weeks and won't therefore need that airbox anymore. is $100 with B&M filter fair?
"I gotta vouche for everything the man from Fabspeed (above) says. Gaaaagious music out the rear end of my porsches tuchas and I get a great kick in the pants every time I blip into 3rd at about 5000 rpm. "
yeah, but mine sounds better - for two reasons: i took out the entire airbox muffler and cut holes in the bottom section of the airbox.
Old 01-11-2009, 10:57 PM
  #42
eclou
eclou's Avatar
Received 1,189 Likes on 582 Posts
oldie but goodie, by Ben Keaton no less. RIP
Quick Reply: Make ur own Fabspeed box for $13.66 &
