987S Blinking Side Marker Lights (with turn signals)
Old 05-07-2006, 11:13 PM
JustJack
JustJack's Avatar
Question 987S Blinking Side Marker Lights (with turn signals)
I know that there is a hack for the 986 to make the side marker lights blink with the turn signals. Does anyone know if this hack works with 987S?
Old 06-19-2006, 12:19 PM
Canada 05 Boxster
2nd Gear
Canada 05 Boxster's Avatar
There is good news & bad re the 986 side marker hack on 987:
The bad: It won't work because Porsche now uses a system buss & front lamp controller to control
each lamp individually; lifting the marker ground & attaching it to a turn signal positive wire won't
provide sufficient filaments to ground through & light the bulb.
The good: Any willing dealer can reprogram "CODE NUMBERS" to return the side marker to it's
turn signal european function, which I believe more important, considering you can't see the
front lights from the side of the car.
Happy Motoring!
Quick Reply: 987S Blinking Side Marker Lights (with turn signals)
