Post your repair / warranty list here
Old 09-20-2006, 07:25 PM
mudman2
Moderator !x4
mudman2's Avatar
Default Post your repair / warranty list here
I thought this might be useful. Post the information related to your repairs warranty or otherwise and I will keep it at the top for quick reference.
No discussion just facts please, I will remove discussion posts, take them into a new thread.
Thanks.
Old 09-21-2006, 08:23 AM
mudman2
Moderator !x4
mudman2's Avatar
Here is my list, this is a list of the new parts fitted, the fault finding processes and faults found would take to much time.
DME Control Unit - (4 or 5)
Towing Control Unit - (3)
Plug and Coils - (all)
Coils - (1)
A/C Servo units, lower dash - (3)
Carden Shaft - (1)
Transmission - (1)
Comfort Control Unit - (2)
Parking sensors (2)
There is more i will have to dig out my records.
Old 10-01-2006, 04:46 PM
droptop
droptop's Avatar
accessory belt 12k (took several weeks to get)
weatherstrip on sunroof 19k
rear door sunshade 19k
transmission 19k (not fixed)
transmission 32k (not fixed)
transmission 35k (not fixed)
transmission 37k (not fixed)
transmission 42k (not fixed)
PHC unavailable 42k (not fixed)
PCM failure 45k (not yet taken in, vehicle is in lemmon law process)
squeeks and loose trim too numerous to mention.....
DT
Old 10-13-2006, 08:12 AM
mudman2
Moderator !x4
mudman2's Avatar
PSM FAILURE WORKSHOP
AIR SUSPENSION FAILURE WORKSHOP
Diagnosed to a steering angle sensor. lets see when I get it back.
Old 10-13-2006, 06:05 PM
Vino
Vino's Avatar
04 Turbo (8/03) build
PCM Failure- fixed (1) warranty
Key Range poor - New fobs now can open doors from 40yds. - fixed (1)warranty
Power steering Pump leak -fixed (1) warranty
Allignment Off - fixed after second time but paid for
Rear hatch Shocks didn't support hatch- fixed-warranty
Dead battery.....recharged for $50
Front Brake caliper paint around Bleed valve peeling- fixed with new front calipers -warranty
Coil pack pencils all replaced w/ spark plugs which were all fouled out- fixed -warranty.
All this with under 12k
Old 10-27-2006, 10:54 PM
mudman2
Moderator !x4
mudman2's Avatar
Default Air Suspension Fault Workshop
Came out of the office at lunchtime and thought my looked really good except it was actually down on its stops.
I started up and it pumped itself back up, no error message.
Tonight I got the the Air Suspension Fault - Workshop
Back to the dealer
So much for the steering angle sensor they fixed 2 weeks ago
Old 11-02-2006, 05:21 PM
mudman2
Moderator !x4
mudman2's Avatar
Replaced Air Compressor 1 955-358-901-01, 2 days in shop Warranty phew !! I wonder how much that would have cost.
Old 11-02-2006, 05:29 PM
LVDell
LVDell's Avatar
2005 Cayenne
15 months old
Zero warranty claims.
2 open recalls performed (glass latch replace, reprogram rear gate latch)
Old 11-18-2006, 04:58 PM
tetongolf
tetongolf's Avatar
04 CTT, 29k miles
8 Coils Replaced
TPMS Not Working - Cleaned Connection at Control Unit & Reprogrammed
Air Bag Fault Code 1217 - Repaired Per TSB
Driver's Side Seat Belt Does Not Retract - Part Ordered
Passenger Side Rear Window Does Not Work - Part Ordered
Michael
04 CTT
92 S4 RS2
Old 11-18-2006, 10:55 PM
Budget M3
Budget M3's Avatar
'06 V6
Passenger side door entry plastic (warped)
Transmission control unit (after major failure and 125 mile tow)--moderate improvement
Transmission valve body--no effect
Transmission--stay tuned...
Old 11-19-2006, 05:45 AM
Ton
Ton's Avatar
06 (0506) CS
- modification kit for lenses
Old 11-21-2006, 11:36 PM
Cay-ute
Cay-ute's Avatar
03 Cayenne S 37K Miles
1. Rear Window Washer Nozzle
2. Gas Gauge Sensor
3. TSB Trim Replacement
4. All Other TSBs
Old 11-25-2006, 04:50 PM
mudman2
Moderator !x4
mudman2's Avatar
Here we go again
Started up this morning, my 8 s now a 4 AGAIN
Same as previous, engine will run but throwing pure gas out the back on one side.
Typical pencil coil shuddering.
Wonderfull !
Dealer, sales dept were open and got me a loaner.
ugh
Old 11-27-2006, 05:36 PM
mudman2
Moderator !x4
mudman2's Avatar
OK another coil went, this time it also killed a "cam sensor" on order for tomorrow.
ugh !
Old 11-30-2006, 08:29 AM
mudman2
Moderator !x4
mudman2's Avatar
Here is the latest invoice from the dealer
File Type: pdf
Quick Reply: Post your repair / warranty list here
