996 Forum 1999-2005
PSE Modded 3.6 Mufflers - how close in sound to a real PSE?
Old 10-11-2006, 08:03 PM
wlee69
wlee69's Avatar
Default PSE Modded 3.6 Mufflers - how close in sound to a real PSE?
I've searched thru the posts of the folks who have modded their OEM cans to be "like" a PSE...though everyone seems to like the results of the sound (at least on the 3.6 cans) how close is it really to the OEM PSE?? I won't get the debate going again on the 3.4 cans vs the 3.6 ones...but nobody really ever said how close the sound came to a PSE.
I've already been given the advice to just buy the OEM PSE, but modding for ~$200 or buying new for ~$2K is a big difference!!!!
THanks in advance,
Will
Old 10-11-2006, 08:31 PM
1999Porsche911
1999Porsche911's Avatar
If you mod the 3.6 cans using the correct size pipe, they will sound exactly like the PSE in bypass mode because that is exactly how Porsche does it.
Old 10-11-2006, 09:14 PM
wlee69
wlee69's Avatar
So what is the correct pipe size???
Old 10-11-2006, 09:44 PM
1999Porsche911
2 inch.
Old 10-11-2006, 09:53 PM
wlee69
wlee69's Avatar
Thanks for the info!!!! Now...to get a stock set of 3.6 mufflers!!!! If anyone has a set they are wanted to sell/get rid of, please PM me!!!
Thanks,Will
Old 10-11-2006, 09:59 PM
1999Porsche911
Thanks,Will
What year car do you have. If you are running a 3.4 engine, try just installing the 3.6 cans on the car and see if the increased noise level suits you. I run cans from a 2003 4S on my 99 and prefer that sound to the PSE. Not as loud, but lower.
Old 10-11-2006, 10:04 PM
SANDOVAL
SANDOVAL's Avatar
2.25" actually fit better when they cut the cap off the 3.4L exhaust cans that I just did.
I also thought this was discussed before but isn't the 3.4 and 3.6 internals the same.
Old 10-11-2006, 10:07 PM
Palting
Palting's Avatar
MAN!! And to think I paid $1500 for my PSE's!!
Old 10-11-2006, 10:08 PM
SANDOVAL
SANDOVAL's Avatar
Sorry Palting... $80 at your local muffler shop
Old 10-11-2006, 11:30 PM
wlee69
wlee69's Avatar
I think that I did read that someone had cut open the two mufflers (3.4 and 3.6) and that they were the same...but then there are still folks who said they are different...and also different in sound. In fact there was a post with someone who had tried both exhaust and they said the 3.6 was more sounding like a PSE than the 3.4 - it was posted by "87turbolook911"
https://rennlist.com/forums/showthre...hlight=pse+mod
Old 01-29-2007, 05:07 PM
waldrondigital
waldrondigital's Avatar
Default PSE mod - 3.4s are different
FYI about 3.4 vs 3.6 mufflers -
I did the MKII version 2 mod (2 1/4" pipe from bypass to outlet) on a set of 2000 (3.4) mufflers this weekend and for all the work, it barely got any louder or throatier - almost unnoticable. I'm waiting to receive some used 3.6s, and will post a follow-up when I've done the mod on them.
If you're thinking of doing the mod on 3.4 mufflers, and want a noticable sound difference - do the version 1 mod that connects the inlet directly to the outlet with the small pipe MKI, v1. Or get 3.6 cans like people in here suggest.
With my first experience modding 3.4s, I'd say the consensus is correct - something's different with the 3.6s that makes them louder.
Hope this helps someone.
Mike
Old 01-29-2007, 10:36 PM
justinmm2
justinmm2's Avatar
waldron,
Eagerly await the results - thanks for keeping us informed
Old 01-30-2007, 12:01 AM
CT03911
CT03911's Avatar
Wlee69, pm'd you. I have stock 3.6 mufflers I'm not using. Went with the PSE.
Old 01-30-2007, 08:57 AM
gota911
Newbies Hospitality Director
gota911's Avatar
A while back, I did the MK II version (2.25” pipe) "PSE hack" on a set of 3.4 ('99 -'01) mufflers. They were a little louder and a little deeper sounding than the sound of the stock 3.6 ('02 -'04) mufflers. However, I was disappointed that the modified mufflers weren’t much louder than the stock mufflers.
I am awaiting delivery of a set of 3.6 mufflers that I will modify in a similar fashion to the 3.4 "cans." Hopefully, I will have this completed within a week. When I have them swapped out, I will report back on my opinion of the differences in the sound.
Old 01-30-2007, 12:51 PM
donuts
donuts's Avatar
I'm also eagerly awaiting my set of 3.6 mufflers to do the MK II mod. I've read about people doing the hack with 1 5/8", 2" and 2.25", is there a consensus on what to use and what differences the sizes will have on sound?
Quick Reply: PSE Modded 3.6 Mufflers - how close in sound to a real PSE?
