Airbag 996 3-spoke Steering wheel in 951 - Now with How-To
Old 12-10-2006, 01:20 AM
gregeast
gregeast's Avatar
Ok, as promised, here's the How-To:
Part #’s
1) 3-spoke steering wheel from 996 or Boxster - 996 347 804 54
2) Contact ring/Slip ring/Clock Spring – 996 652 211 00
3) Air bag w/colored crest - 996 803 089 02
Here’s a pic of the clock spring:
Modifications
1) Steering wheel - The steering shaft of the 944 is shorter than a 996 and so there are not enough threads exposed to attach the 24mm nut to secure the steering wheel to the shaft. I took the wheel to a friends machine shop and we removed ~1/4” of material on the inner side of the steering wheel where the steering shaft goes through, using a 1 3/8” bit. This was enough to allow me to thread the 24mm nut on.
2) The new clockspring is just slightly too large in diameter to fit through the plastic trim piece behind the wheel. The hole needs to be dremelled out by ~1/8" to allow the clock spring to fit through.
These two pictures show the nut before machining the wheel and the wheel after being machined:
2) Wiring
- The airbag wires coming off the clock spring that go to the car (not to the airbag itself) use the same keyed connector as the 944 so no way to screw up there.
- The 996 horn wires have two grounds (the 944 only has one). Connect the brown/white wire from the clock spring to the brown/white wire on the car. I cut off the connector from the old clock spring for this and spliced it onto the brown/white wire from the clock spring.
- I spliced a longer piece of wire to the solid brown ground coming off the clock spring and ran it to the grounding point above the driver’s side foot well.
- Connect the horn wires off the clock spring the tabs inside the wheel.
- Connect the airbag to the clock spring.
Pricing
I bought the wheel on Ebay for under $70. It had some dye coming off of the top of it (which I repaired, look for another how to on that topic soon). The clock spring was ~$40 on Ebay. The air bag was by far the hardest to find and the most expensive. I bid on several over the past couple of months but they were always too rich for my blood. I ended up buying a brown air bag on Ebay for right at $300. Because it was an odd color it was a little cheaper. I dyed it black and it looks great.
So, for ~$400 I have a spiffy new wheel that looks stock, feels nearly as nice as a Momo and still retains the airbag. I'll probably sell my old wheel and air bag and recoup some of that as well.
Additional notes from another install: (Thanks to Stephenwz968!)
Just to add to the install notes:
I just finished up last night with the install of a 996 3 spoke airbag wheel in my 968. I have a few other things to add, so I'll just give a quick rundown of the process.
1. Buy 3 spoke wheel/airbag and either the 996 or the 993 style clockspring.
2. You must cut the horn connector on the back of the new clockspring and the original.
3. Wire your old connector to same color wire on the back of the new clockspring.
4. Splice on a length of wire to the other horn wire and run it to a grounding point on the body.
5. Install the new clockspring with the grey harness at the top-do do this you may have to move the turn signal/wiper/cruise assembly forward a bit-you gain access to this by removing the plastic piece to the right of the steering column. This is removed by taking off the cover of the heater/ac controls and taking out those 4 screws, taking out the screw under the steering column and screw that hold the piece to the dash. The signal/wiper/cruise assembly has an 8mm bolt on a collar holding it in place loosen it, pull the assembly forward, and then run the wiring behind it and install the clockspring. Push the assembly back as far as it will go, and then tighten the 8mm nut.
6. The plastic cover that goes over the assembly needs to be modified a little bit more than Greg originally expressed. I made the clockspring hole bigger, cut off the plastic spacers on the rear so it fit closer to the signal/wiper/cruise assembly, and made the cutouts for the levers about 1/4" bigger so the levers would still pull forward.
7. Install plastic cover, reinstall trim piece on dash.
8. Install steering wheel that has had 1/4" milled out to gain some threads on the steering shaft.
9. Install airbag, horn contacts in the the wheel.
10. Admire your new airbag equiped wheel!
Hope that helps anyone looking to do this mod...I really like it, and it's a little different than the standard CS wheel install!
And the final product:
PS Credit for this goes to several pioneers at 968.net. A few guys did this a couple of years ago on that forum with both 4 and 3 spoke 993/996 wheels and I am indebted to them for the information.
Last edited by gregeast; 04-25-2008 at 11:42 AM. Reason: Added notes from Stephenwz986
Old 12-10-2006, 01:22 AM
gregeast
gregeast's Avatar
Originally Posted by hockeydude
A little OT, but i just noticed the fluid resivoir in your sig. How did you get it to be part of the crest?
35thSLP, a fellow Rennlister, made that to my design using self-adhesive vinyl. I'm sure he can make more, drop him a PM if you're interested.
Old 12-10-2006, 01:29 AM
hockeydude
hockeydude's Avatar
cool. i had never seen anything like it before.
Thanks for the write-up. i'm sure that it will help many 'listers
Old 12-10-2006, 02:04 AM
gregeast
gregeast's Avatar
Hockeydude: The coolant tank decal started out as a joke. I wanted a new tank but couldn't bring myself to spend $150 for a new one when the old one worked just fine. About that time there was a thread on coolant tanks where people were kicking around different ideas to paint/cover-up they're coolant tanks. I was standing in the garage, looking at the tank when it dawned on me that the shape was roughly the lower left corner of the crest and it was even the right color for the background. I mocked one up with cardboard, kinda liked it and then 35thSLP made it real.
Old 12-10-2006, 06:52 AM
jgleano
jgleano's Avatar
thats the Best interior i've seen....at least from the pics of others on here. beautiful...just beautiful
Old 12-10-2006, 07:17 AM
Dan87951
Dan87951's Avatar
Gorgeous, im gonna copy you! Thanks for the write up definitely helpful!
Old 12-10-2006, 07:39 AM
JohanvdWalt
JohanvdWalt's Avatar
Congrats on an amazing car, the best I have seen and believe me I have seen many.
Old 12-10-2006, 11:20 AM
gregeast
gregeast's Avatar
Thanks Johan, it's been a lot of fun putting it together. I have one more thing I want to do to the interior and then I think I'm done, more on that to come...
Old 12-10-2006, 12:08 PM
tod84944
tod84944's Avatar
Greg,
On the bottom of your dash, console and shifter boot, is that stock color??? Also, did you dye those pieces.
Todd
Old 12-10-2006, 12:44 PM
gregeast
gregeast's Avatar
Todd: The color is champagne (or cashmere if you're the 968/993 sort) and it is the color that the stock seats were. I had the dash and console recovered by Rob M Budd in leather, black on top and champagne on the bottom. He also made the french stitched shift boot. He's a Rennlister and a great guy to work with. His website is www.928leather.com You might recognize a the pics of the 944 dash on that site No affiliation, just a very happy customer who let him use pics of my dash.
Old 12-10-2006, 01:41 PM
  #26
Fishey
Fishey's Avatar
993 4 spoke here I come (when I get the moneyz) lol...
Old 12-10-2006, 02:12 PM
  #27
gregeast
gregeast's Avatar
Based on what I read on 968.net I don't think there are any other issues with the 4-spoke, be sure and post some pics! BTW, I bought a nice shiny new air bag crest from an Ebay vendor for $40 shipped and it's really nice. It would work to put on top of the embossed crest on the 4-spoke wheel if you're lookin' for a little more bling.
Old 12-13-2006, 11:08 PM
  #28
testarossa_td
testarossa_td's Avatar
Old 04-25-2008, 08:49 AM
  #29
Stephenwz968
Stephenwz968's Avatar
Thanks to Greg for a great write up, and for answering my questions when I got into a jam!!!
Steve
Old 04-25-2008, 11:14 AM
  #30
gregeast
gregeast's Avatar
Congrats Steve and thanks for taking the time to add to the write up. Would you mind if I cut and pasted your instructions into the my write-up, in case people (this would never happen I know, LOL) don't scroll down to your post?
And, more importantly, we need pictures man!
Congrats again.
Quick Reply: Airbag 996 3-spoke Steering wheel in 951 - Now with How-To
