5 Speed rebuild post - Process pics & tips (G28-05)
Old 07-18-2007, 09:21 AM
  #121
John V
John V's Avatar
Pics should be back up. If someone can explain how to upload them here, I'll give it a shot otherwise, my pic hosting account goes dormant if I don't access it every 30 days.
Old 07-18-2007, 12:09 PM
  #122
BC
BC's Avatar
Thanks John. Thats the way I did the spring.
I am still working on the backlash. I thought it said .76, but its actually .16.
Old 07-18-2007, 04:16 PM
  #123
Vilhuer
Vilhuer's Avatar
John's pics, part 1.
Old 07-18-2007, 04:23 PM
  #124
Vilhuer
Vilhuer's Avatar
John's pics, part 2.
Old 07-18-2007, 04:29 PM
  #125
Vilhuer
Vilhuer's Avatar
John's pics, part 3.
Old 09-01-2007, 07:44 PM
  #126
rock2001
rock2001's Avatar
Sorry to drag this thread back up, but I was trying to duplicate your spring procedure to allow the transmission to center on the 2-3 gate. My bends are not as nice as yours, but for now it seems to work. I'm happy with it right now, although I hope it stays on.
However, when I put everything back together, I found a separate issue. The shifter didn't want to rotate into the 1-R gate. The "U-spring" seems to be catching the vertical tab on the shift finger. Based on your pics it looks the same. The vertical tab has an indent that the U-spring sits in, but to move into 1-R it has to push it's way out of the tab. Did you have any problems with this?
I just put a shim between the U-Spring and the front of the shift finger to separate them so that the spring doesn't sit in the indent, and it looks good now. But was this a bad idea? I don't see anything else wrong, but it didn't seem like a problem when I took it apart.
Thanks
Old 09-01-2007, 08:02 PM
  #127
a4sfed928
a4sfed928's Avatar
I think it is because the indent is in the verticle part to increase the resistance to enter reverse and if I followed your post you have defeated this.
Old 09-01-2007, 08:22 PM
  #128
BC
BC's Avatar
I drilled an additional hole in the main selector shaft so that the spring would not move too much, and put another one of those roll studs in.
Old 09-02-2007, 11:58 AM
  #129
rock2001
rock2001's Avatar
Yes, I guess I essentially disabled that R-1 mechanism. It just felt like it was way too hard to get into that gate, by hand anyways. Maybe it would feel better in the car, but the spring should be good enough to keep me away from that gate when needed.
Ahhh, another pin for the spring. I like it. I'll have to be careful drilling that out now that everything is back together.
Old 12-15-2012, 08:27 AM
  #130
Landseer
Landseer's Avatar
Epic Thread.
Shame that rennlist didn't save John's pictures along with his narrative.
(Though they where thoughtfully reposted at post # 123)
Quick Reply: 5 Speed rebuild post - Process pics & tips (G28-05)
