997 GT2/GT3 Forum 2005-2012
Alignment specs
Old 03-20-2007, 11:55 PM
jbeanstalk
jbeanstalk's Avatar
Default Alignment specs
For those of you lucky enough to already be tracking your GT-3, what alignment specs are you running / recommending?
Thanks!
Reg
Old 03-21-2007, 12:43 AM
doc2s
doc2s's Avatar
interesting that porsche has changed the rear camber setting from -2 to -1 40' according to a service document posted on rennteam. probably to reduce understeer.
Old 03-21-2007, 12:45 AM
Jean
Jean's Avatar
A Porsche Motorsports source recommends -3 degrees camber front and -2.5 rear. You need to turn the struts around and buy some spacers to be able to do it.
Old 03-21-2007, 10:06 AM
Unitah
Unitah's Avatar
What else did this service bulletin say?
Running more negative camber in the front and less in the rear? Isn't it more common to run more negative camber in the rear? Can someone explain this change to me?
Old 03-21-2007, 10:14 AM
Jean
Jean's Avatar
Unitah, It was not from a service bulletin.
For racing you run more camber in the front than rear..(almost) always.
Street cars need to understeer to be safer for the average user. This is not the optimal performance setup though.
Cheers
Old 03-21-2007, 10:31 AM
doc2s
doc2s's Avatar
the service bulliten explains in details how to do the alignmnet. the specs are what was given in the manual. i think for the track setup porsche recommends -2/-2.5 front/rear. there was an old post here with detailed alignment specs.
Old 03-21-2007, 10:41 AM
Jean
Jean's Avatar
Aplogies, I thought he was addressing his question to me.
The recommended settings above are not a racing setup. For serious track driving I would go with -2.5 Fr and Rr. the same, these cars understeer, but it is about personal preferences and driving styles.
Old 03-21-2007, 01:37 PM
doc2s
doc2s's Avatar
agreed.
this has been posted by pentium on rennteam. these are the street values. see the note at te end.
The following values relate to the empty weight, i.e. full fuel tank/fluid reservoirs, vehicle with tools, but without driver or additional weights.
· The toe-difference angle value is also influenced by the vehicle height. For this reason the measured result must be evaluated accordingly. No action is necessary in the case of small deviations from the toe-difference angle’s required value as long as the value to the right and left is almost the same.
Wheel alignment values
911 GT3/911 GT3 RS (997)
RoW/USA
Front axle
Toe unpressed (total)
+ 6' ± 2'
Toe difference angle at 20° lock
- 1° 50' ± 30'
Camber (with wheels in straight-ahead position)
- 1°20' ± 5'
max. difference, left to right
10'
Caster
8° ± 30'
40'
Rear axle
Toe per wheel
+ 13' ± 2'
5'
Camber 1)
- 1°40' ± 5' 1)
10'
1) Altered camber value on the rear axle which is also valid retroactively (from start of production). Previous value: - 2° ± 5'.
Old 03-23-2007, 11:17 PM
Apex Late
Apex Late's Avatar
Hey Guys,
I just picked up my new GT3 today. After 50 kms it was already in the shop getting ready for the track. I took it to a very well respected shop in Toronto to have a baseline set-up put on it for the track. We were all shocked to learn that we couldn't get more than -2 in the front!!
This shop set-up my 996 GT3 previously and has experience with Cup versions of the GT3. That being said this was their first trip under the new 997 GT3.
Can someone help me out? Rightly or wrongly so I was under the impression that the 997 had more adjustability than the 996. I'm disappointed because I would prefer to run more camber up front.
I've been following this post and it doesn't seem that many people have them set up for the track yet. If you are a Porsche specialist with an opinion I will gladly hear from you as well.
All that said guys....after 200 kms the car seems very different from the 996. I wont offer my opinions yet as I haven't really DRIVEN the car but it sure is good lookin'
Old 03-24-2007, 01:11 AM
Jean
Jean's Avatar
There are some "washers" you need to buy and if you want aggressive camber then you need to rotate the struts. I think there was a thread discussing the washers, run a search, I am sure you will find more info.
Old 03-24-2007, 09:49 AM
Unitah
Unitah's Avatar
Are they "washers" or milled aluminum spacers? If they are the spacers you are talking about, they come in 1mm, 2mm, 5mm and 10mm increments (I think)...
Old 03-24-2007, 10:13 AM
doc2s
doc2s's Avatar
unitah,
are you planning a trip to the track any time soon?
+1 to what unitah said. go to http://www.carnewal-europe.com/main.htm and look under the suspension section for 996. you will see a picture of the camber shims. i was told that you could order through a delaer.
Old 03-24-2007, 11:54 AM
Jean
Jean's Avatar
Maybe spacers is the right word. But you do need them We set -3 deg camber in the front with those (not sure which size the shop used) and turning around the struts.
Old 03-24-2007, 04:08 PM
Unitah
Unitah's Avatar
Set -3 in the front, nice. If you could get in there with a vernier caliper and figure out what thickness spacers (camber shims, whatever they are technically called), that would be great!
Now, I am a bit confused, what is the purpose of "turning the shocks"? I am assuming you mean rotating them 180 degrees? Does this achieve more offset, or camber, or what?
Yes, I have my first Autocross on April 1st. Then first track event April 14 and 15 at Pocono with MetroNY PCA. By then, I have to have the alignment done, full cage installed, motor mounts, LWFW / clutch, and hopefully get that pesky exhaust system off the car!!! hahaha Oh, and graphics package installed, don't want to forget that.......... we are a sick bunch..........
Old 03-24-2007, 06:59 PM
doc2s
doc2s's Avatar
rotating the front shocks will allow you to get more camber but the min. camber would be around -2.5 or so.
Quick Reply: Alignment specs
