Mobil 1 Oil forumulation again
Old 05-09-2007, 02:38 PM
Geoffrey
Geoffrey's Avatar
Default Mobil 1 Oil forumulation again
It seems that Mobil has reintroduced their old Mobil 1 oil (prior to extended performance version) in a new formula. Below is taken from their website
Website Link to Mobil 1
"Why are you reintroducing Mobil 1 15W-50?*Have there been any changes to the formulation, or is it identical to the previous product?"
Mobil 1 15W-50 is being reintroduced based on popular demand.*Mobil 1 15W-50 provides higher viscosity, designed to provide extra protection for performance vehicles and vehicles that operate in severe service, such as towing, hauling and racing.*Additionally, Mobil 1 15W-50 contains higher levels of anti-wear (ZDDP or Zinc DialkylDithioPhosphate) that may be required for certain racing applications and camshaft designs.*This is a new Mobil 1 15W-50 formulation and is not the same as the product that was marketed a few years ago.
Mobil 1 15W-50 is also recommended for older valve train designs that may benefit from a higher level of anti-wear normally not required for newer generation vehicles.*Mobil 1 15W-50 will also provide better anti-wear protection for higher valve spring tensions in certain racing engines.
Old 05-09-2007, 02:43 PM
smlporsche
smlporsche's Avatar
So will they be offering the extended performance version as well as this new/old formulation or just this new/old version??
Old 05-09-2007, 02:46 PM
schwank
Herr Unmöglich
schwank's Avatar
Fug... so which version do I want now?
Old 05-09-2007, 03:13 PM
Geoffrey
Geoffrey's Avatar
Extended performance is still being offered and is a different formula that the "new" "old" Mobil 1 formula. Both are available in multiple viscosities. You want the Mobil 1 version, not the Mobil 1 Extended Performance version.
Old 05-09-2007, 03:21 PM
LVDell
LVDell's Avatar
Uh-oh. Here we go again with the ever popular oil debate
Old 05-09-2007, 03:26 PM
chrisp
chrisp's Avatar
This is hard to follow. I know they have had some changes in the marketing side of their division so perhaps this is new blood trying to stake their claim. What's interesting is they claim higher ZDDP but it's still an SM rated oil. The SM standard reduces Zn and P levels because they harm catalytic converters. So perhaps this "new" formulation has higher levels than the previous iteration but not as high as the SL rated version of M1. I am using 10-40 Mobil 1 High Mileage because it's SL rated and I am experimenting with viscosities. You don't want it any thicker than it needs to be to get acceptable oil pressure. Too thick saps horsepower, increases friction, and reduces cooling capabilities. For example, I used 5-30 at my last track day where it was about 70 degrees and I had excellent pressure. My temp gauge read 180-190 all day (stock 3.0 with a small-ish front mounted cooler)
Old 05-09-2007, 03:36 PM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
I gave up on Mobil 1 and went back to Amsoil. I ran that stuff 25 years ago in my 914 2.0 which used to cook conventional motor oil. Never had a problem or temp/wear related issue in 6 seasons of tracking that car.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 05-09-2007, 03:42 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
If I understand it correctly, Mobil 1 15W-50 Red Top is back, just not the exact formulation of the 'old' 15W-50 red top. ZDDP levels, more modern API rating issues, etc.
I still have ~ 50 gallons of the 'old' Mobil 1 15W-50 red top in 5 gallon jugs (cleaned out Wally World), so I figure by the time I've gone thru it, I'll have figured out exactly what is going on with M1 15W-50.
Old 05-09-2007, 04:28 PM
chrisp
chrisp's Avatar
Gallons or quarts?
Oil has a shelf life. I am no expert but from the settling I have seen in 18-24 month old bottles I would say use it up in the next 2 yrs.
Old 05-09-2007, 04:32 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Gallons...like I said, I bought out the local Wally Worlds before the stopped making the 'old' red top 15W-50.
I was unaware that (unopened) synthetic oils had a shelf life. Thank you.
Old 05-09-2007, 04:48 PM
sjanes
sjanes's Avatar
When Mobil1 changed the 15-50 to the new API SM spec, I switched to their V-twin 20-50 synthetic motorcycle oil as it still contains high levels of Zn and P anti-wear additives.
Old 05-09-2007, 05:14 PM
daigo
daigo's Avatar
OK, is it the "New Coke" or the "Classic Coke"
Old 05-09-2007, 05:30 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,087 Likes on 1,188 Posts
I see a product data sheet for almost everything on the Mobile site - except the "new" (old) 15w-50 discussed here.
Has anyone found the data sheet to do a side by side with the other 15w50?
Old 05-09-2007, 06:44 PM
multi21
multi21's Avatar
Received 2,988 Likes on 1,767 Posts
Can someone confirm or deny that synthetic oil has a shelf life and if so, what is it?
Old 05-09-2007, 08:54 PM
Dan V
Dan V's Avatar
Default Mobil 1 EP doesn't have a "use by" date
This limited warranty is valid for 15,000 miles or 1 year from the date [purchase or installation]
http://www.mobiloil.com/USA-English/..._Warranty.aspx
Quick Reply: Mobil 1 Oil forumulation again
