PSS9/Monoball strut failure
I was on my way to work this morning, and suddenly the steering wheel on my 996 goes about 20' to the left. I limped it back home and was very suprised to find that the strut shaft sheared off right under the monoballs.
The car sits fairly low, PSS9 set on stiff, TRG monoballs. My assumption was/is that the monoball was somehow binding and causing the shaft to fatigue until it eventually broke.
Has anyone seen a failure like this before? I know I'm a little extreme running the monoballs on the street, but it seemed necessary since I kept ripping through the stock upper strut mounts.
What the heck do I do now? If I put another strut in I'd expect the same failure to occur eventually.
The monoball hammered away at the snap ring. There is a bit of surface rust on the bottom of the joint, but doesn't seem to be binding. The joint itself moves smoothly but stiffer than it should be.
Here are some pics:
Here are some pics:
So, you've had it break a few times? Always the same side?
I bet the top of your spring hat isn't allowing enough movement of that monoball... The spring hat might be hitting the bearing mount, and then the strut tries to move more which causes that shaft to bend/flex a little below the hat (about where it broke). After a number of cycles, the material work hardens, develps a stress crack, and then breaks.
Great idea about the spring hat, I'll have to take a closer look at that and see if it may be binding. Hopefully I can buy a single strut someplace...
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I dont see why the snap ring is starting to fail since it only experiences load at droop. Could you post some pics of the shaft showing the failure?
I did this also 2 or 3 times. I was breaking my right rear each time. I raised the car up to Euro spec ride height and that fixed the problem. This was on a 993TT with Pss9's. Something about the geometry of the suspension. The car had camber plates/monoballs as well. My fix came based on the advise from Steve Weiner. Hope this helps.
