993 Forum 1995-1998
Sponsored by: DashLynx
Piper Motorsports roll cage pics
Old 09-18-2007, 03:08 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Default Piper Motorsports roll cage pics
Hey folks,
I recently decided to get a full cage in my car and went with respected cage builder Mitch Piper. http://pipermotorsports.com/ Mitch and Robbie were absolutely great to work with. Mitch did everything I asked him to do and fielded my many, many questions and offered good advice on how to proceed.
I thought carefully about whether to get X bars and use RS door panels or to go with the NASCAR-style bars and gut the doors. The X bars are supposed to be stiffer due to triangulation, but ingress and egress can be limited. At just under six feet and 180 lbs, I’m an average-sized guy. However, I did not want to get a steering wheel quick release since I’m very happy with my Momo Mod .07 wheel and the wheel-to-hand distance. Two more things to buy (I would have to get a steering wheel with a flatter dish) and one more thing to remember to do (having the wheel come off while driving could lead to a bad day. I hate bad days.) No deal.
Regardless, Mitch feels that the NASCAR bars are safer because of the extra distance between the bars and the driver. He's seen his cars get hit and feels that the driver is safer with the NASCAR bars. I asked him to do a modified NASCAR bar by dropping the top bar down a bit to help me get in and out of the car. Although it's preferred to have the bars meet at one point, specifically where the A-pillar bar meets the knee bar, the distance of bar from the knee bar point to the actual welded point is so short that I don't think the placement will make much of a difference in a side impact.
Piper's work is super-clean. All of the tubes are placed as close to the body panels as possible. He removed the stock knee bar and put the cage knee bar as far away as possible. I like to sit really close to the wheel and wanted the bar to be as far away as possible. He also carved away part of the dash to mount the A-pillar cage bar as close to the stock A-pillars as he could.
The doors retain the stock side impact bar and use the stock glass. Mitch used trick quick release pins that hold the glass in place. Pull the pin and the glass drops right down. Since I tow with an open trailer, having a weathertight car is crucial, as is the security factor when staying overnight at less-than-desirable locations. Going with Lexan made no sense at all since Lexan is harder to slide in the stock window tracks and is more vulnerable to hooliganism. Besides, the stock glass was already paid for. For the door release, Mitch welded up some thin tubes and ran some cabling through it, looped it and cushioned it with some black surgical tubing. I added some trim pieces to to the areas where the sheetmetal was removed to prevent cuts. http://www.pegasusautoracing.com/pro...p?Product=4346
For maximum protection and stiffness symmetry, I went with dual roof bars and cross diagonals out back. It didn’t add that much weight to add another bar or two, and I’ll be all set for any regs that require more bracing. I am going to have to train the neighbor's two year old kid to clean my back window...
I'm not sure what the weight is, but gutting the door panels and removing the foam insulation in the back seat offset the extra tubing. With 1/8 of a tank of gas, I still have to carry about 30 lbs of ballast to make weight, so the full cage didn’t make the car even porkier than it already is.
Mitch painted the cage, too, which is a challenge in a car with a full interior (When is PCA going to do away with this requirement? We have to make weight, anyway. The guy who wants to drive his car off of the street and club race it would not be at a disdvantage if he had a full interior. Sorry, getting side-tracked.), which I made even more difficult by asking that the cage be painted silver. Mitch painted most of the tubes while they were out of the car and then welded them in, using carboad to mask off the interior. The silver paint is a readily-available industrial-grade Rustoleum. Although it's not a 100% perfect match for my polar silver, it's close enough and looks great. Touching up scratches is very easy since the paint blends so well.
I also just installed the Recaro Pro Racer HANS seat and Pole Position seat (nabbed on Ebay for $350!!) What an ordeal that was; nothing like just plopping my old GT3 seats into the car. I used Sparco sliders for both seats. For the Pro Racer, I stuck with the Recaro side mounts but had to drill the rear mounting points to drop the seat height a bit. It made a one hell of a difference. I’m going to put spacers (3” and 4” diameters to spread the load) in between the seat and the side mounts to compensate for the narrower seat needing to fit the wider floor pan mounting points.
For the Pole Position, I used Sparco side mounts and had to cut away part of the rear ears to clear the seat belt holes. Thankfully, I have a chop saw with a metal cutting blade. BTW, the Sparco side mounts matched up perfectly for both the Pole Position and the Pro Racer. Additionally, keep in mind that you’ll have to cut the tubular Sparco seat release bar in half and insert a steel rod to lengthen the release to mate up with the 410mm wide stock floor pan mounts that the sliders must attach to. I ended up using JB Weld for the first time and have been very impressed with it, although it’s not in a very highly stressed application. The stuff was easy to work with and looks just like the seat other seat release that Piper properly welded up.
All hopes of being to pull all of the racing stuff out of the 993 and sell it as a street car just went out the window…
Old 09-18-2007, 03:13 PM
allill
allill's Avatar
Mark,
That cage looks amazing man! They must've taken a lot of time fabricating, quality work.
Old 09-18-2007, 03:20 PM
CAHRERA
CAHRERA's Avatar
Man Mark,
Awesome you've definitely have gone way pass beyond the pt of no return to stock. I guess if your doors ever have an issue with the door stops it won't be a problem.
Old 09-18-2007, 04:30 PM
clubsport1
clubsport1's Avatar
Quality workmanship!
Old 09-18-2007, 05:12 PM
LPM911
LPM911's Avatar
Looks great Mark! I have the X bars in my 964 and yes it is a bit cumbersome on entry and exit. Can't wait to see it at the track and compare.
Old 09-18-2007, 05:44 PM
Harvey Yancey
Harvey Yancey's Avatar
You gone past the point of no return now ...
Nice job ... very clever solutions ...
Old 09-18-2007, 05:48 PM
David in LA
David in LA's Avatar
Wow..that is really nice work!
Old 09-18-2007, 05:58 PM
Paul902
Paul902's Avatar
wow! awesome looking craftsmanship!
Old 09-18-2007, 06:30 PM
Arrwin
Arrwin's Avatar
No way you will be able to say "completely stock" or "never been tracked" if you ever decide to sell.
Old 09-18-2007, 06:48 PM
Freier
Freier's Avatar
Outstanding! Looks like a lot of work went into this, and it came out beautifully.
Old 09-18-2007, 06:59 PM
Mark in Baltimore
Thanks, guys. I hope I never have to use it.
Old 09-18-2007, 07:37 PM
forklift
forklift's Avatar
Wow!
Old 09-18-2007, 08:33 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Great work. Do you still need those spacers made we talked about?
Old 09-18-2007, 08:48 PM
Mark in Baltimore
Chris, I do, I can make do with 3" for the front but prefer 4" for the load spread. Is 4" out of the question for you? Maybe I can have a vendor drop ship them to you if you can't. Please let me know.
Also, the thicknesses I need are 11mm (0.43307”) and 13mm (0.51181”). I assume you can cut it that precisely?
Thanks!!!!!!!!!
Old 09-18-2007, 11:51 PM
AOW162435
Seared
AOW162435's Avatar
I dropped by Mark's house yesterday and can confirm that the tube bends and welds are first rate. Nice work!
Andreas
Quick Reply: Piper Motorsports roll cage pics
