CDC Removal
Old 09-18-2007, 09:29 PM
mudman2
Moderator !x4
mudman2's Avatar
Default CDC Removal
Anyone stripped down the rear to install/unistall the CDC ?
Old 09-18-2007, 11:03 PM
MadFox
Pepper Bartender
MadFox's Avatar
I've stripped down..... wait this is a G rated forum... Nope, never have... but my CDC compartment came stripped.. and it has been very, very, useful being "stripped" in the past few days!
Old 09-18-2007, 11:11 PM
99firehawk
99firehawk's Avatar
theres 3 screws on each side of the changer
if you remove the 10s that hold the changer bracket
you can get the chnager out through the hole
but you need to yank the trim to put it back in
Old 09-18-2007, 11:54 PM
MadFox
Pepper Bartender
MadFox's Avatar
if you remove the 10s that hold the changer bracket you can get the chnager out through the hole but you need to yank the trim to put it back in
not to differ.. but I've been in there working on a beta project and it looks dang difficult to take out.. the bracket appeared to be only take-out-able (is that a word?!) if you pulled the entire rt. rear panel (not just the access panel).. as a result I had to figure out an alternate location for my "project".
Old 09-19-2007, 11:54 AM
JFScheck
JFScheck's Avatar
Hey MadFox - you installing a sonabouy launch system on the ole' Pepper to track them subs in Alabama?
Old 09-19-2007, 07:02 PM
sigs
sigs's Avatar
I was hoping he had figured out how to rear-mount one of those .50s we were talking about, and was using the rear panel area for the belt feeder.
Old 09-19-2007, 08:49 PM
MadFox
Pepper Bartender
MadFox's Avatar
JOhn-boy... welcome back to Pepper-ville.. the sequel! I'm under a top secret confidentiality agreement... but you and sigs are close... think islamo anti-terror dirty sniffer! the new Thule roof rack has the 50's hidden!
Old 09-21-2007, 01:00 AM
99firehawk
99firehawk's Avatar
you un do the bracket to get the 3 screws on the chnager to the bracket in the back.
then you pull the changer t
then the bracket
instalation is almost impossible and you have to pull the trim
Old 09-21-2007, 09:24 AM
mudman2
Moderator !x4
mudman2's Avatar
On that basis here is some help for others, I will be doing this soon and will report back with pictures.
Old 09-21-2007, 11:23 PM
JFScheck
JFScheck's Avatar
Sweeeet!
Old 09-23-2007, 03:30 PM
mudman2
Moderator !x4
mudman2's Avatar
OK its out, there is more info required, I will post later, here are the parts I had to remove to get it out and a view and the BOSE amp with the CDC already removed from underneath it.
Old 10-17-2007, 01:30 PM
Cayenne|17
6th Gear
Cayenne|17's Avatar
oh man all this work mudman to get it out i hope you replaced it with something
Old 10-17-2007, 01:44 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Huh, so that's what a Bose amplifier looks like. Not very attractive nor impressive looking is it?
Oh wait, what else do I see in that picture, below the amplifier.....no, it can't be.....it's only claimed to have been previously sighted and photographed in court documents.......could it be.......yes, I think it is........
The infamous 1D6 towbar control unit !!!!!!!!!!!!!!!!!!!!!!! Run away, Run away.......
And with that, I finally reach a personal milestone in Rennlist history.....my 10,000th post.
How poetic that # 10,000 would be related to a Bose amplfier and a 1D6 factory towbar control unit module......almost like it couldn't have happened any other way....
10,000....how time flies, how I miss Larry (R.I.P. ).....I wish he were here for this.
Old 10-17-2007, 03:03 PM
sigs
sigs's Avatar
ltc,
Congratulations on your !0,000th post!
What are you doing to celebrate? Having Peter the Great for dinner? Maybe with a nice Chianti and some fava beans?
Old 03-03-2012, 05:56 PM
Schmides
3rd Gear
Schmides's Avatar
mudman,
In the pic with the amp installed inside the rear panel, there is a cable laying on top of the amp (the one where you can see the a small amount of purple wire at the end). What is this supposed to be connected to? I have all the cables connected into my amp that I can and I have this same cable left over, but not sure where it goes!
thanks
Quick Reply: CDC Removal
