View Poll Results: Was the GT-R quicker?
Yes, it was quicker - the GT-R is a quicker car
22
22.68%
Yes, it was quicker - even though the Porsche driver did mistakes
11
11.34%
No, it wasn't quicker - the Porsche driver did many mistakes on purpose to make the GT-R pass
14
14.43%
This whole race was a joke - it was obvious the Porsche was treated really bad to make it look slow
50
51.55%
Voters: 97. You may not vote on this poll
Nissan vs. Porsche on track. Find the flaws?
#46
"....The boost went up by 0.1kg/cm^2 (1.42psi) due to the reduced backpressure,......."
Errr..... that might explain some of the power attributed to the new exhaust system. According to the article, Nissan engineers also leaned the A/F ratio; and they did this despite the additional boost pressure? Normally, more fuel is required with commensurate boost increase unless lightening holes are desired in the pistons. Perhaps the engineers were too sloppy and the engine was running too rich before the mod, but I don't think so.
Since when is boost pressure on a modern, ECU-equipped engine dictated by the exhaust system? Answer: It isn't. The modern ECU sets the boost limit, unless of course, Nissan or someone modifies the ECU to increase boost to produce more "cat-back" power.
Color me skeptical,
Sherwood
Color me skeptical,
Sherwood
#47
The physics of it tells us the car is making much more than 480 crank. The C6Z06 with 500+ crank HP and 3200lbs of weight is turning 120mph trap speeds, the 430 Scuderia with 500hp can pull the same trap but weighs "3000lbs", so it is highly unlikely that the GTR can do the same with an extra 600-800 lbs unless it is pumping out closer to 550hp
#48
So you're right, the physics do tell the story.
#49
True if you use the numbers posted above, but I used the numbers from a different car mag, which I trust more then some random stuff on the internet.
True to that, I doubt it is going to optically appeal to the western crowd
#50
The 997tt with 480hp and AWD traps 116-117mph. Most stock Z06's are getting low to mid 120's. 128mph is not representative of the average stock Z06. The GTRs tested to date make much more than 480hp. Perhaps they were factory tweaked beyond production levels.
A 4000# car inc driver turning an 11.7 at 122 mph needs 530hp at the crank assuming 2wd. This is about the weight of a GTR
A 3700# car inc driver turning an 11.7 at 122 mph needs 496hp at the crank assuming 2wd. This is about the weight of a 996/997tt
A 3400# car inc driver turning an 11.7 at 122 mph needs 456hp at the crank assuming 2wd. This is about the weight of a Z06.
http://www.dragtimes.com/horsepower-...calculator.php
#51
This car is absolutely not making 475BHP... The numbers don't add up. And the few that have been dyno'ed are proving that. Believe what you will, but this car is probably making about 570BHP, based on 20% drivetrain loss (AWD calculation).
Mike
Mike
#52
The well over 4000lbs w/ driver GT 500 has trapped 118 in IDEAL conditions, compare apples to apples. A lot is being blown out of proportion because people arent looking at the details, wait until the car is tested at some altitude and you wont see and AVERAGE of 120 mph, then your numbers will come down.
#54
Only one of the big three mags in the US corrects for conditions, everyone else posts the ET and time they got (motor trend I think, and they always have the fastest times if it's that one). If that was the case you wouldnt see a 119 for aZ06 on one mag and a 125 on another, or else somoneones conversion got all screwed up.
#55
Note to people who don't know about Best Motoring and shows of this type from Japan.
A Japanese car can never lose a race in those videos.
I am surprised that the 997 TT did not get passed by an NSX and an Integra Type R, as well.
WWE matches have more intrigue about the outcome than those "races". But it is fun to listen to the presenters get exited about everything. Their pronunciation of English terminology is a hoot. I remember them yelling "raunch contororo" when getting an M3 CSL off the line. Now I can't take the SMG gearbox seriously anymore.
#56
#58
I have watched a few of these Best Motoring shows, and you do have to take their results with a grain of salt. I do remember watching an episode where the old guy drove the yellow 996GT3, and annihilated the field of NSX's, WRX Spec C's, Evo's, and the like... It was probably one of the more accurate 'races'.
And, I've seen an episode where a F360 gets schooled around a track by the latest model of the NSX. The drivers claimed the F360 was hard to control at limit. We all know there are many more parameters (car set up, driver, etc...) at play, and getting a quantitative analysis is nearly impossible from these kinds of shows.
These shows were entertaining back when I all I wanted to watch was a bunch of wild exaggerated driving around a closed circuit. Now, I just tune into Speed Channel and watch the best racing television has to offer...the Australian V8 Supercars!!!
#59
my friend just got from japan where he went to the tokyo auto salon and brought back some goodies... im still a fan of the p-car, but i will admit, the GT-R is and always has been an impressive car. can we at least agree to that?
#60
No, "WE" can't.... However, I've owned Zcars for two decades now. However, Nissan has a long history of skewing the facts and playing with numbers. I'll bet large sums of money that the initial results being reported eslewhere are true. The GT-R IS MAKING OVER 500WHP.
Believe what you want, but the results speak for themselves.
Mike
Mike
