*****mObridge Group Buy*****
Moderator !x4
I am pleased to announce that we have a group purchase in place (if there are enough takers) at a discounted price of $499 per unit.
This is only available to Rennlist MEMBERS. To participate please PM me and I will authorize you with MOBRIDGE-USA who will complete the order.
The mObridge unit is capable of expansion from its base iPod / Aux (RCA input) to include Bluetooth and Video.
Moderator !x4
Hey Kevin
Although I have not seen it yet, its a Parrot OEM integrated solution built into the mobridge box. It also uses the addressbook function of pcm if available. It should be available shortly as an addon via exchange.
i read through the other post and is it difficult to do the install in the front? I looked around in the back and did not see both of the cables in the back, so might try it if the front install is not too difficult.
thanks
thanks
Pepper Bartender
depending on your model.. the rear cables can be difficult to get to.. dig around and/or you may need to removed the panel.. but that is still by far the easier install. You can do the rear in 30 minutes.. with the way mObridge sets up now and the cable connections (the only hard part).
