Time for a cleanup...parts FS
Old 02-03-2008, 12:02 PM
fourniem76
fourniem76's Avatar
Default Time for a cleanup...parts FS
I have wayyy too many parts now time for a major cleanup...
Part Qty Price each Comment
Transaxle 944 NA 1 $250 Non LSD, no cooler
Engine Block 944 turbo 1 $100 Stock bore, 1 damaged cylinderne needs sleeving
Engine Block 944 NA 106mm bore 1 $500 Balance shafts deleted
Cylinder head 944 turbo 1 $350 Stock
Cylinder head 944 NA 1 $250 Small porting
Cylinder head 944 NA 1 $400 Big porting, shaved .055, 951 valve springs
Cam box 944 2 $50
Camshaft 944 NA 1 $100
Camshaft 944 turbo 1 $100
Lifters 16 $80 80$/set of 8
Crankshaft 944 NA 2.5l 1 $250 lightened
Crankshaft 944 turbo 1 $300 Stock
Connecting rods 951 4 $300 Forged, Lightened, balanced
Connecting rods 944 NA 4 $150 150$ for set of 4
JE Pistons 106mm 12.5/1 4 $500 Brand new never installed with lightened pins & rings
JE Pistons 106mm 12.5/1 3 $150 Identical to new ones above… @10 hrs on them
JE Pistons 106mm 11.0/1 3 $150 Flat top… @20 hrs on them
Pistons 944 NA 2.5l 8 $150 150$ for all 8
Oil pan 944 NA 1 $50
Exhaust headers 944 NA 1 $75 Primaries only - 4 into 2
Exhaust secondaries NA 1 $50 2 into 1
Injectors 944 NA 4 $75 75$ for the set of 4
Injectors RC 75lbs 4 $150 150$ for the set of 4. Rebuilt never mounted
Fuel rail 944 NA 2 $40
Fuel damper 951/944 2 $25
Fuel pressure regulator 3 bar 1 $40
Air flow meter 944 1 $50
Intake manifold 944 NA 1 $50 Stock
Intake manifold 944 NA 1 $75 Ported, modified orientation
Throttle body 944 NA 1 $125 Bored to 65mm
GT35 replica turbo 1 $350 never mounted. Bought rebuilt paid 800$
DME computer 1987 NA 2 $150
$5,940 Buy the whole lot for: $5,000
OTHER PARTS AVAILABLE
Torque tube 944 NA 1 $150
Torsion tube 944 NA 1 $100
Door passenger’s side 1 $50 Red, partially disassembled
Calipers 944 NA 1987 6 $75 Rebuilt, for all
Motor mounts 944 NA 2 $50 50$ for right & left side mounts
Crossmember 944 NA 1 $75
PM me or call at 514-212-5589
Thx
Michel.
Old 02-03-2008, 01:15 PM
DMB14
DMB14's Avatar
For the motor mounts, do you mean $50 each?
Old 02-03-2008, 01:24 PM
schwank
Herr Unmöglich
schwank's Avatar
Sure I see this post right AFTER I tell my fiancee I'll pull back on the car spending for a bit
Old 02-03-2008, 01:51 PM
Wipeout
Not Special
Wipeout's Avatar
Eric,
"Just one more thing..."
Old 02-03-2008, 02:01 PM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
That'll learn ya.
Old 02-03-2008, 10:22 PM
fourniem76
fourniem76's Avatar
Default motor mounts
Hello DMB14,
no.. I meant 50$ for both ....
none of the prices include shipping..
thx
Michel
Old 02-03-2008, 10:31 PM
jbrill
jbrill's Avatar
i need a fuel pressure damper for my s2. please pm me regarding condition/kms on them
Old 02-04-2008, 12:13 AM
Wallace
Wallace's Avatar
Hey Jordon, just so you know, those fuel pressure regulator and damper won't fit an S2.
Old 02-04-2008, 04:46 AM
jbrill
jbrill's Avatar
oh? thanks for telling me! i guess i'll just go buy a new one then haha. thanks again.
Old 02-04-2008, 11:31 AM
V2Rocket
Rainman
V2Rocket's Avatar
i might get those injectors, ill let you know later tonight.
Old 02-05-2008, 02:37 AM
svochuck
svochuck's Avatar
pm sent .
Quick Reply: Time for a cleanup...parts FS
