911 Turbo (930) Forum 1975-1989
The new digital warm up regulator has now hit that market
Old 04-08-2008, 03:29 PM
Kevin
Kevin's Avatar
Default The new digital warm up regulator has now hit that market
http://unwiredtools.com/utcis.asp#utcispt
I have not tested it, but I have been aware of the development.
Right now it looks very promising.
Old 04-08-2008, 04:59 PM
Autobahn
Autobahn's Avatar
Subscribing
Old 04-09-2008, 04:28 PM
stu.p
stu.p's Avatar
Me and others have been looking at this for several months now,,Has anyone yet ordered or tested the PT version yet for our turbo charged cars??.
Does look like the fix our cis cars need!!
Old 04-09-2008, 07:04 PM
E-man930
E-man930's Avatar
seems easy enough...
http://unwiredtools.com/manuals/UTCI...anual%20A1.pdf
Old 04-09-2008, 07:11 PM
jetskied
jetskied's Avatar
Just received it. I will be installing it over the weekend. Does anyone have any base line settings I should try for a car with k27 7200, headers, 8:1 compression and garretson cooler?
Old 04-09-2008, 07:42 PM
JBL930
Not Forgotten
JBL930's Avatar
I was on the list for one last year for a while, i had many e-mails and phone conversations with Frank Ableson regarding this unit, I was promised it last year but the development obviously took a lot longer than he first envisaged, I had no need for it in the end. The initial software had some glitches which meant that some of the adjustments didn't save, make sure you check your saved program to see that it is as you want it., I'm sure they have ironed this out though.
If the unit works as it's intended then it will be fantastic, I'm really looking forward to seeing some results, I know it's not EFI but for CIS turbos it's the next best thing, keep us informed
One thing that Frank mentioned is that you can tune it remotely using a dongle and your laptop, sounds bloody good to me!
Old 04-10-2008, 11:32 AM
Ag02M5
Ag02M5's Avatar
Subscribed!
Old 04-12-2008, 01:00 PM
JBL930
Not Forgotten
JBL930's Avatar
Hows the instal going Jetskied, i know there's a time difference and your probably having breakfast but get your bloody finger out! Take LOTS of pics, and be quick, i'm sat here waiting
Old 04-12-2008, 02:17 PM
biglicks
biglicks's Avatar
+1, please!!
Old 04-13-2008, 11:50 PM
Autobahn
Autobahn's Avatar
Any news? Update PLEASE!!!
Old 04-15-2008, 03:45 AM
jetskied
jetskied's Avatar
I just did the basic install. It is nothing other than to replace a stock WUR. You just have to remove IC and air cleaner first. One of the problems with the unit is that there is a small ECU that you must mount under the hood as the wires are not long enough to try and place it inside the cabin. The best spot I found is on the right side wheel well near the rear shock. I do wonder if the unit will survive the heat under the hood. I'm not finished yet as I'm taking my time, but I will post pictures later.
Old 04-15-2008, 05:02 AM
biglicks
biglicks's Avatar
could it be fitted under the sound deadening material on the bulkhead, or does it need clear airflow? Alternatively do you think the wiring could be lengthened without any negative impact allowing mounting in the cabin area?
Steve
Old 04-15-2008, 05:04 AM
JBL930
Not Forgotten
JBL930's Avatar
I thought the idea was that it fitted under the fuse panel in the left hand side of the engine bay? That was what i was led to believe, is it not long enough? Ed, check your e-mail
Old 04-15-2008, 11:30 AM
WERK-I
WERK-I's Avatar
Steve
Depends.....if the leads are carrying TTL voltages for the sensor(s) that would mean it's plus&minus 5 volts which in this type of environment, 10 feet (and that's pushing it) is the max. My guess would be not to out guess who ever designed this thing.
Old 04-15-2008, 12:50 PM
911rudy
911rudy's Avatar
I know from printers that there is a limit to the length of cords that carry voltage sensitive info. Most complex printers don't recommend cords, (USB) of over six feet.
Quick Reply: The new digital warm up regulator has now hit that market
