Nippondenso 10PA20C Compressor Rebuild pics
Old 04-20-2008, 04:01 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,548 Likes on 1,232 Posts
Default Nippondenso 10PA20C Compressor Rebuild pics
After re-doing all the o-rings in my A/C last summer, replacing the expansion valves, drier, and the relay in the head unit, the only things not up to snuff in my A/C were the two hoses that run to and from the compressor, the PITA pressure line that runs from the drier to expansion valve (R&R’ed now, see https://rennlist.com/forums/showthre...ighlight=drier) and the compressor itself. Well, at least one of these is leaking, as I lost my freon charge over the course of a few months. Time to fix that.
In addtion to R&R'ing the pressure line and new compressor hoses, I decided to re-seal the compressor. To do this one needs a gasket kit, a and a shaft seal kit. The only special tools that the 10PA20C requires are some internal and external snap ring pliers (including a big one for the snap ring that holds the clutch coil to the housing) and a shaft seal protector- more on that in a bit.
I wasted about 2 weeks waiting for shaft seal kits convinced that I’d gotten the wrong one (see https://rennlist.com/forums/showthre...ght=compressor)
The shaft is about 13.5 mm in diameter, as was the ID of the old shaft seal. The new seals I got measured less than 11mm ID. Turns out this is ok- The carbon seal itself is deformable and can be ‘stretched’ over the compressor shaft. In order to properly install it, though, one needs a shaft seal protector. I ended up a MasterCool # 91319, from an outfit called Polar Bear (http://www.polarbearinc.com/PBPC/homepage/Product.html) for $15.
So- To rebuild the compressor:
Have the system evacuated unless you’re sure the system is empty- My charge from last year had completely leaked out again, hence the decision (after taking with Greg Brown about it) to replace both compressor hoses and re-seal the compressor.
A complete set of large combination wrenches from 17 to 32 mm, as well as a 1-1/16 and a 7/8” combo wrench are needed for all the combinations of fittings you’ll find on the large diameter suction hose going to the compressor and the smaller pressure hose coming from it. There is only one fitting where you cannot counterhold, and that's a 19 mm fitting at the bottom of the downpipe from the drier to the condensor.
Removal of the compressor entails undoing the pressure and suction hoses at their fittings, then loosening the 10 and 13 mm nuts on the belt tensioner, and then undoing the two 17 mm bolts that hold the compressor to the mounting bracket. I pulled this bracket just to clean up the area:
Do yourself a favor and take lots of pictures of the orientation of the bracketry that hold the compressor and hoses to the block. Here are a few shots:
Front:
Bottom:
Passenger side:
Start by undoing the 10mm bolt that holds the clutch hub/cover plate. An oil filter wrench will keep the cover plate and compressor from turning.
Lift off the clutch hub, taking care to keep track of any shim washers that are between the clutch hub and the face of the compressor shaft- These set the ‘air gap’ between the clutch hub and the clutch itself. Air gap spec on a 10PA20C is 0.3 to 0.6 mm. I had two shims of different thicknesses.
Here’s the front of the clutch:
The clutch/pulley assembly is held by a weird wavy-shaped snap-ring, and the clutch just pulls off easily.
Here’s the clutch/pulley bearing (Koyo DAC3052-3RR90, see the 'bearing madness thread for more on clutch bearings):
Then undo the Philips head screw that holds the clutch wire, and then remove the big snapring that holds the clutch coil to the compressor body. It’s indexed with a small pin. Sorry, no picture!
You’re now staring at the face of the compressor, clean it up with some brake cleaner. Lots of oily greasy crap under the clutch coil. Perhaps my leak is/was from the front seal?
Remove the 5 case through-bolts with a 6 mm hex socket. My compressor was a rebuilt unit back in 1997, whoever did it used some sort of sealer on the threads. The gasket kit comes with five new brass washers for these bolts. Gently lift the compressor front plate off the shaft. On the inner face of the compressor front head is the shaft seal, held in with another snap ring:
Once the snapring is out the old shaft seal can be tapped out with a deep 10 or 11 mm socket:
Then remove the felt seal from the nose of the front head with a pick or somesuch:
To install the new seal, lube it up with compressor oil (I’m staying with R12 so I used ester oil) and install it by tapping it in (straight!) with a 19 or 21 mm socket.
The gasket kit includes three large (113mm?) o-rings to re-seal the case sections. No way in hell was I going to split the middle of the case, but I replaced the front and rear piece gaskets, lubed up first with compressor oil.
I cleaned up the faces of the case with brake cleaner, then installed the shaft seal protector over the shaft and oiled it well.
Now- this pic shows the old shaft seal at right, with an ID of 13.5 mm. The middle seal is ACKits.com’s #21-34629, and probably would have worked. But I screwed it up installing and removing it from the front plate,so I reinstalled it briefly and used it for practice. It has been put on the shaft once and pulled off. The seal on the left is the seal I got from Polar bear inc, part # SS 767HNBR. At bottom is the shaft seal protector, with its beveled top, to ease the shaft seal over the nose of the shaft.
So with the new seal installed in the front plate, re-assembly is just a matter of oiling up the seal, putting the shaft seal protector over the shaft, and gently pushing the front plate and seal down onto and over the compressor shaft. Then remove the shaft seal protector, reinstall the felt seal (the kits don’t come with a new one) and you’re all set:
I tried to install the case bolts but had some difficulty doing so –felt like they were stripping. So I pulled the rear plate off the compressor to look at the threads. Ouch:
I ended up chasing the threads in the rear plate and running a die (M8 x 1.25mm) over the bolts to clean them up. Note the gray rubbery sealant crap in the recess in the tap:
Once these were done, I cleaned off the cutting oil then reassembled the compressor, torquing to a final value of 19 ft lbs. i didn't use any sealant on these bolts. I reinstalled the coil, clutch/pulley, and clutch hub, torquing the front hub bolt to 9 ft lbs.
Here’s measuring the air gap, at ~0.5 mm:
Last but not least I changed the gasket at the manifold plate, which is held on with 4 6 mm hex bolts. I added 6 oz of oil to the compressor before buttoning this up.
Ready to go back in:
I installed the compressor back in the car, replaced the drier, connected all the lines, and pulled a vacuum. The gauge hasn’t budged in about 6 hours now- if it’s still good in the morning I’ll pull a few more hours of vacuum on it and then charge it up.
This better work…..
Old 04-20-2008, 06:56 AM
Landseer
Landseer's Avatar
Very nice write-up and pictures, thanks! I now have a ray of hope that my system might also be salvageable.
Old 04-20-2008, 08:10 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
As a side note if on A/C repairs you find any metal shavings inside the lines they should be flushed out and new reciver drier and expansion valve/s installed.
Finding metal shavings is a sign that you need a new compressor. Dont install a new compressor unless the lines have been cleaned
Old 04-20-2008, 09:57 AM
Jadz928
Jadz928's Avatar
Wow Rob, great writeup. You make this project seem quite doable.
Chris,
So it appears an AC R&R is on your list as well. I'll be tackling this in 3 weeks or so. To include fixing inop actuators, new evap, receiver/drier (of course). Time permitting, an AC compressor and hose R&R. And a R134 charge.
Hey Roger,
If you read this, could you add the comp. gasket kit and hoses to my quote? Should I assume to order the bearing and seals from the suppliers Rob listed?
Thanks!
Old 04-20-2008, 10:17 AM
Dwayne
Dwayne's Avatar
Rob,
This is a great writeup and excellent pictures! I had always thought I was stuck buying a new compressor (or rebuilt) when mine failed. Now I can rebuild my own with the help of your writeup!
I just replaced my compressor on the '84 but I still have the old one - I'll put this one on the project list. I'm keeping your writeup and pics in my "928 Greatest Tips" file!! THANKS!!
Old 04-20-2008, 02:05 PM
dprantl
dprantl's Avatar
Is there any reason why you removed the two big bolts on the top? Porsche added another bracket and used a body-mount compressor just so it would be easier to reinstall the compressor by putting the four bolts upward instead of trying to line up the two big bolt holes front-to-back.
Dan
'91 928GT S/C
Old 04-20-2008, 02:36 PM
Rob Edwards
Archive Gatekeeper
Hey Dan-
The paper towel holder- shaped compressor bracket that bolts to the block at four points has two lower M8 bolts that point straight up into the block, but the two upper mounting bolts run horizontally into the block. The anterior one is no problem, but the rearward one is located ABOVE the heat shield and is a PITA to install even with the compressor removed- you need a 13 mm socket on a 6" extension. I can't imagine getting to it with the compressor still attached, let alone torquing it properly.
That said, it can be a pain to get the compressor back up in there, when you put it into place you need to make sure that the bushing in the compressor mount isn't pushed too much towards the front of the car or you'll never get the mounting bosses on the compressor up and in between the flanges on the mount. The bushing can be pressed rearward with a channellocks. Also, the rubber portion of the compressor hoses both start out stright but require some pretty significant bends to line up with the condensor and the suction pipe.
EDIT: D'oh, I see what you mean. If you're just removing the compressor, yes, you could just drop the compressor itself off the swivel bracket (held by the 17mm bolts to the block mounting bracket) that it directly mounts too. In my case I had that whole area stripped anyway, as you need to remove the compressor and air pump to R&R the pressure line that runs to the expansion valve.
Stan- good point about the metal shavings, the one I show was threads from the rear plate. The rest of the inside of the compressor was nice n' clean. And despite having to chase all the threads, the bolts all torqued properly, so hopefully it'll behave.
The gauges on the vacuumed system didn't budge overnight, so I'll charge this afternoon.
Old 04-20-2008, 04:06 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Excellent, Rob. Same basic process applies to the earlier compressors, like my 6E171. Glad you sorted out the seal kit issue.
Old 04-20-2008, 05:10 PM
LT Texan
LT Texan's Avatar
Great write up and pictures, just one more item on my list while changing over from early Bosch to Nippon Denso....
Old 04-20-2008, 08:45 PM
Rob Edwards
Archive Gatekeeper
Just a few more pics from filling the system. a while back I splurged $20 and got my EPA 609 certification so I could buy R12 from Ebay. After pulling vaccum for a few hours this morning the vacuum was still at 30 mm Hg:
So- I closed both the low and high side valves, turned off the pump, then disconnected the high side hose. I connected up the yellow hose to my R12 tank, then cracked open the R12 and loosened the yellow hose at the manifold for 1-2 sec to fill the line with R12 then tightened it down. Then I zeroed the scale (got a good deal ($70) on Ebay last year, it's good to 100 lbs down to 1/10 oz or 2 grams.)
Here's the R12 tank before taring to zero, total weight = 32+ lbs:
With the system under vacuum, you need to jumper the pressure switch in order to get the compressor to kick in for filling:
Then- start the car, turn on the A/C button with the fan on high (and crank the rear air fan and thremostat to full cold), and open the low pressure side valve. Since the low side connects to the suction line, the compressor will slowly pull freon into the system, at a rate of about 2 grams per second. I added a total of 1150g:
Then close the low side valve and the valve on the tank, disconnect the low side, and done!
The center vent temp is at 21oF by IR gun (I know they're not accurate, but it's cold....) So at least the compressor didn't immediately explode. I will report back when it does.
So if this works, I spent $20 for certification, $300 for R12 (but only used 2.5 lbs, so figure $25 worth), $200 for a vacuum pump, $70 for the scale, $12 for the seal, $20 for the compressor gaskets, $35 for a drier, $15 for the shaft seal protector and $20 for a ton of o-rings. That's about $400 for all the tools you need to re-do the system, assuming your compressor is rebuildable. Not bad considering a reman compressor is $500 alone. I don't even want to think what all this would've cost at the dealer in 1997.....
Old 04-20-2008, 09:08 PM
Jadz928
Jadz928's Avatar
Rob,
I'm coming over. See you in about 33 hours. Good job.
I'm fighting about whether to stick with R12 or go to R134.
Old 04-20-2008, 10:18 PM
justin
justin's Avatar
21 degrees! Holy Moly!!!!!
Mine gets down to only 50 degrees!
Old 04-20-2008, 11:08 PM
dprantl
dprantl's Avatar
Haha, that looks exactly like my vacuum pump. I use a $30 hanging fish scale; I set up a ladder and hang the fish scale from the middle of the ladder, then hang the 30lb freon cylinder from it. It's accurate down to the ounce. My brother also has R12/R22 certification, but we pretty much use R134A only in all our cars (except one if his that's now running a propane/isobutane mix ala Australian cars). I remember when I rebuilt the 6E171 compressor on my '86. That car is still holding its R134A charge today.
Oh, and you don't have to jumper the switch. Just open the low and high sides with the car off and let the freon get sucked in (since the system is under vacuum). Then shut off the high side, start the car and turn on the A/C.
Dan
'91 928GT S/C
Old 04-21-2008, 12:41 AM
borland
borland's Avatar
Don't the casing bolts have copper gaskets under the bolt heads?
Those vacuum gages are worthless for pulling a vacuum strong enough to remove water. You need a gage in microns.... something like this...
http://www.omega.com/pptst/DVG-64.html
or this
http://www.omega.com/ppt/pptsc.asp?ref=DVG-60
Old 04-21-2008, 01:08 AM
Rob Edwards
Archive Gatekeeper
Dan-
Thanks for the tip on the low pressure switch! Of course the vacuum would draw the freon in- given another few years of deep thought I might have come up with it myself......
Borland-
I'm pretty sure the washers are brass, they look like it, anyway. Your point about the micron gauge is well taken, although as Dr. Bob pointed out to me a few weeks ago: Ok, so you get a micron gauge- the gauge won't make a bit of difference about the ultimate vacuum pulled by the pump. Whaddya gonna do? go buy a bigger pump? I just played it safe and pulled vacuum on it for about six hours before charging. I figure that's more pump time than I would have gotten at any shop, and that's with a new drier too. I'm afraid it'll have to be good enough!
Quick Reply: Nippondenso 10PA20C Compressor Rebuild pics
