Damp carpet along door interior
Hey guys. First post. Just acquired a 2005 Guards Red Carrera coupe.Have wanted one since I was 12. Took ownership about 2 weeks ago, and since then I have noticed that moisture is wicking up the interior lower door carpet on both doors when the sills get wet. Any ideas. Seems strange that it is occurring on both doors.
That IS strange especially since it is both doors.
My C4S has no such issues and I do not recall seeing any similar posts describing your problem.
Was the car ever in an accident? Sounds like something that should not be too hard to fix with a little insulation.
Welcome to Rennlist and congrats on your car,....I love Guards Red!
Have your dealer flush the drains with air. I also suggest that you try to dry out the interior of the car. There may be more water/moisture inside than you think.
Team Owner
I'm betting the sunroof drain tubes are clogged, though I don't even know if they run in the same places as the 996.
Congrats on your new ride!
Would you like pictures with or without the Shop Vac. . I will post some photos once I get a chance. BTW Great forum. Thanks for the quick responses too.: Now back to football.
I forgot to mention that there is an electrical black box under one of the seats that controls many electronic functions. That box is located at a low point on the floor and depending on how much water you have inside the car, the box could short circuit creating all kind of electrical gremlins and then you will have to have the box replaced ($$$).
I suggest that you have your dealer look at your car ASAP. Meanwhile, I strongly suggest that you keep the car away from water and rain!
Follow up to problem. Took it to the dealer, no clogs in the drains. I thought maybe by chance I left the window cracked open on either side so I paid careful attention. The dealer was equally puzzled. They lubricated the seals and said wait and see. Weeks went by without a problem unitl today. We got a ton of wind driven rain today in Philly, and now the carpet is damp again. Service Technician said the next step is to replace all the seals (Under Warranty). What a pain.
I know , I know Post Some Pictures........
Have they looked at the windshield? was the windshield ever replaced?
I doubt that both door seals failed. I am more inclined to think that it comes from the firewall, either a poorly sealed windshield or something else on the firewall. Please keep us posted.
Thanks for your help. I spoke with the dealer. They have a colorized paste that can be placed around all vulnerable areas one spot at a time, then they can soak the hell out of the car. I also told him that it didnt make sense that both door seals failed at the same time. He kinda concurred, and admitted that he had never seen this problem before either. Hopefully I will have an answer by next week..
Your automatic window retractors, or whatever they are called, aren't defective, are they? You know, the feature that slightly retracts your windows when you begin to open a door? I had a GTI years ago that developed a wet carpet problem in the rear driver side. The problem was that rain was simply running down the side window into the door and dripping out of the bottom of the door. Don't know if this could happen in a 911 or not.
