944/S2 cab/951 parts for sale
UPDATED LIST
I’m selling all of the rest of my parts now that my 951 is running. Help me get rid of these parts!
All items are “as removed” and will be shipped USPS unless otherwise requested. Shipping is NOT included in pricing. I can take cash, USPS money order or paypal.
Thanks!
S2 Cab parts
-Left and right quarters tops. (the plastic covers that go over the panels) One mount tab is broken off, but it looks like they are just glued on, so you should be able to use the tab from your damaged ones. $150.00 both Now $100
- Top boot cover- Black. In great shape with no broken buttons or fading. Could use a dry clean to just clean it up a bit. $300 Member price- $200
-Cabrio top- S2cab/ 968 cab. Cloth needs to be replaced. Top is complete as removed with outer covering/ inner liner/ frame/ rods/. One support beam has been repaired by being welded. Worked great and you can’t see the support when the top is together anyway. The seals are there and work, but they are old. $400 Pick up preferred but will ship to interested buyer NOW 300
944/S2/951 parts
-A/C condenser – early connection type. $40 Now 30
- Coolant expansion tank (S2) Yellow but good. $25
- 951 Side skirts – All 4 pieces in Good shape. One broken tab in non essential area. Included broken tab and hardware. $75 SOLD
- Hood- Crystal metallic in color. Great shape. $50 pick up only.
-S2/951 OEM radiator- Great shape/ no leaks. $60
- Steering rack- Seems to be in good shape. It is a remanufactured rack. I don’t feel any play side to side. $75 SOLD
- Windshield washer tank- Great shape $30
-Gauge cluster surround- Excellent shape $40
-Power steering pump $30 SOLD
- 951 fuel regulator- $5
-S2/951 starter great shape rebuilt unit- $60
- Rear wiper motor and blade- $20 SOLD
-951 Rear valance. Crystal metallic in color. Great shape with no broken tabs. Paint flaking near where exhaust would be on one side. $150
- Steering shaft- great shape $10
- S2 ABS Brake Master Cylinder with reservoir $20
- 951 sachs “super touring” front strut assemblies. Includes struts/ springs/ mounts. Look pretty new $150 SOLD
- 951 rear KYB shocks. (Gas-a-just) $30 SOLD
-16mm rear sway $25
-18mm Rear sway with bushings/ brackets $40 SOLD
- Drivers side Window motor and regulator- $40
- Passenger side Cabriolet window motor and regulator- $40
- Cabriolet quarter glass and frame. $10 each
- Headlight motor and linkage- $20
-Wiper motor and assembly- $20
- Late control arms- $60 each or $100 both
-Steering Wheel w/ airbag Needs new skin - $20
-ABS Pump- $75
- ABS Computer- $40
- ABS Sensors front and rear- $50 per side or $80 All
- Cabriolet Sealing window edges- $10 both
-rear drop links and eccentric bolts for sway bar- $50
-P.S. reservoir and lines- $25
- Cabriolet Top lock handle- $20
Pics upon request…
Thanks!
Clint
Thanks!
S2 Cab parts
944/S2/951 parts
-16mm rear sway $25
-ABS Pump- $75
- ABS Computer- $40
Pics upon request…
Thanks!
Clint
