Leaking manual gearbox! Help needed......
Old 09-03-2010, 03:46 PM
Thoomas
Thoomas's Avatar
Default Leaking manual gearbox! Help needed......
Hi!
My gearbox is leaking oil and in one week I´m supposed to drive at Nurburgring!!
The leakage is in the front of the gearbox. Its when I´m on the track, during braking and shifting down that a big cloud of oil comes out at the back of the car. Not to popular among the other racers!
Its messy under the car and mostly on the drivers side. So what to do now?? Cancel the trip or try to solve the problem. To me it seems to be somewhere on the top of the box cause it doesnt leak at all in normal driving or standing still. Anyone now if there is a frequent problem with leaking gearboxes and if so where does it leak?
I can get all the gaskets and sealings by expressfreight from Germany on wednesday or thursday.
How many working hours will it be to take out and putting the gearbox in again?
Thankful for any help!
Old 09-03-2010, 05:04 PM
jeff spahn
jeff spahn's Avatar
How did you get the car matte black?
Old 09-03-2010, 05:16 PM
Landseer
Landseer's Avatar
All the little 10 mm bolts on the top cover were loose on mine.
Not sure if you could get a hand / little gearwrench up there or not.
Old 09-03-2010, 05:29 PM
LT Texan
LT Texan's Avatar
handful of pepper
(sorry)
LOVE THE SUEDE!
Old 09-03-2010, 05:41 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
May I suggest a couple adult diapers or half a box of maxi pads!
Old 09-03-2010, 06:35 PM
Thoomas
Thoomas's Avatar
Originally Posted by Dan Perez
handful of pepper
(sorry)
LOVE THE SUEDE!
Or maybe some Barrs!
Old 09-03-2010, 06:41 PM
Thoomas
Thoomas's Avatar
Will try to get there and reach them. Any sign of yours leaking at the top gasket? Did you remove your box yourself?
Old 09-03-2010, 06:43 PM
Thoomas
Thoomas's Avatar
Its a paint job with a silk clear coat.
Old 09-03-2010, 06:53 PM
Landseer
Landseer's Avatar
Yes, I've worked on 2 this month and both leaked significantly from the top.
Mine are 1984s, they are probably different than your 1990. Repair tme depends on your skills and tools and support. . Maybe you can lower the cross member just enough with transmission attached to reach critical points on the box. I don't know. Others familiar with S4/GT arrangement and clutch should suggest the sequence.
There may be reverse switch that is broken and leaking, also, take a hard look. Also front seal where shifter rod enters box. Good pictures will help the other good mechanics here give you ideas.
Old 09-03-2010, 06:56 PM
rawky
rawky's Avatar
Is a stop leak type additive not a viable solution for the trip to Nurburg?
Old 09-03-2010, 07:14 PM
Thoomas
Thoomas's Avatar
Well, it could be but I dont know any for stopping oilleaks. Any suggestions?
Old 09-03-2010, 07:40 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,577 Likes on 1,244 Posts
I sure wouldn't put anything in the tranny except gear oil. Can't imagine what any sort of stop leak would do to the friction plates in the PSD.
I haven't thought this all the way thru, but how about this:
If you can put the car high up on jackstands or a 2 post lift, you might be able to:
1. Undo the top of the rear shocks, and the swaybar links.
1a. Drop the exhaust from the cat back, and remove the resonator heat shields
2. Remove the 6 bolts holding the front mounts of the rear control arms,
3. Remove the inner rear crossmember to body bolts (M12 x 45
4. Remove the air cleaner box
5. Get a pair of M10 x 130 bolts from a hardware store.
6. Replace two (1 on each side...) of the outer rear crossmember bolts (M10x75) with the M10x130 bolts, thread them in part way.
7. Support the whole rear crossmember/tranny with a floor jack
8. Remove the other 2 outer rear crossmember bolts
9. You ought to be able to lower the whole thing nearly 2 inches until it's resting on the longer M10 bolts. Might have to undo the PSD line, the e-brake brackets, etc. But this would give you better access to tighten the cover and/or reseal the top and replace the breather. Make sure the breather's pointing in the right direction (forward and 45o to the right (?))
Old 09-03-2010, 07:47 PM
Thoomas
Thoomas's Avatar
Ok, so the reverse switch goes into the box. Right now any pictures wont help cause theres oil all over the place!
The front seal is also a candidate. Another theory is that its coming trough the bleeder on the top due to the top gasket beeing broken under the bleeder. Thought on that anyone?
I really appriciate your help!
Old 09-03-2010, 08:01 PM
Thoomas
Thoomas's Avatar
Seems like the right way to go. Did the similar procedure when I changed the sway bar. My english is some what crappy so heres some questions:
1. Ok
1a.Ok
2. rear control arms?
3.ok
4. Is there an air cleaner box?
5. Ok
6. Ok
7. Ok
8. Ok
9. e-brake brackets?
Can the breather/bleeder leak oil if the gasket is ok?
Thanks!
Old 09-03-2010, 08:02 PM
Landseer
Landseer's Avatar
Picture with oil is what you want to show.
Quick Reply: Leaking manual gearbox! Help needed......
