996 Forum 1999-2005
Painting Bumperettes - DIY - (now with after mounted pics)
Old 02-13-2011, 07:19 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Default Painting Bumperettes - DIY - (now with after mounted pics)
Given that I just spent a bunch of money on suspension – there is no way I could justify to the other half spending $300 on painted bumperettes from Bumperplugs. So I decided to give it a try as a DIY. Figured if it failed, then I would have to buy them
Sorry, but these are less than attractive.
Inputs:
  • Sandpaper various grits (120 grit to 2000 grits)
  • Flexible primer for bumpers
  • Spray bomb Arena Red Metallic
  • Clear Coat
  • Sandable high-solids primer (not shown)
  • Brake cleaner and rags (not shown) – used to clean surfaces after sanding
Total Cost: $75
Total Time: 4 hours (over 3 days)
Step 1
Remove Bumperettes (6mm? Hex socket or Allen key ) – takes 2 mins
Clean bumperettes with soap and water (discover all kinds of little nicks in the surface and hope that primer fills them)
Step 2
Sand to remove current, rubberized, pebbled finish. I started with 200 grit and quickly went to 120 grit as they are much harder that they look). This took quite some time (1 hour) to get finishes that I like and there was still pebbling in some locations.
Left - not sanded; Right - sanded
Up close sanded
Step 3
Prime with flexible bumper primer (2 coats)
Sand with 400 grit (note getting at the openings at the bottom is not easy)
After priming this, I was not happy with the unevenness in the surface, so I decided to use the high-solids primer to fill in the imperfections (I had used it successfully in the past on bumpers).
Step 4
Prime with high solids primers (3 coats)
Sand with 400 grit
Step 5
Apply two tops coats of Arena Red Metallic
Step 6
Three coats of clear
Step 7 (not completed yet)
Wet sand with 2000 (1500 grit if required) to get rid of orange peel.
Buff with compound and wax - well worth it. Makes a huge difference
Step 8
Re-mount (when it’s not snowing outside)
Sorry it took a week. In finishing I accidentally burned through the clear coat on one and hard to refinish it.... Oops
Assessment
Not as good as Bumperplugs, but good enough from 5 feet.
Paint match looks pretty close
Big question – durability. If they don’t last, then I get to place an order in the future to Bumperplugs
Old 02-13-2011, 07:35 PM
Gaspasser19
Gaspasser19's Avatar
WHAT??? No picture ON the car?! Looks like a nice job though!
Old 02-13-2011, 07:39 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Will update when snowing stops.
Old 02-13-2011, 08:32 PM
redridge
redridge's Avatar
looking good.... but need installed pics asap!
Old 02-13-2011, 08:49 PM
Mark I
Mark I's Avatar
Great job! Nice that you took the extra time to snap the pics & share. Should look perfect after you wet sand & buff.
Old 02-13-2011, 08:57 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Nice write up! I'll bet they look good on the car, but hey, how can we tell?
Old 02-14-2011, 12:08 AM
Van
Van's Avatar
Fantastic! From the pictures, it looks quite nice.
Old 02-14-2011, 12:26 AM
nick49
nick49's Avatar
Looks nice!
I'm always happier when I DIY, aside from the money saving.
Now you do your console and instrument surround next.
Old 02-14-2011, 01:27 AM
francars
francars's Avatar
Great write up - great dyi
Old 02-14-2011, 02:26 AM
V225
V225's Avatar
Awesome! This might be in store as an upgrade one day.
Btw can you take a pic of the car with the bumperettes removed? Is there a gaping hole, or does it look alright?
Old 02-14-2011, 07:55 AM
robert r
robert r's Avatar
Looks good, nice work...
Old 02-19-2011, 02:36 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Default Finally installed
Colour match is pretty good and the finish way better now that they are wet sanded and buffed.
Here they are mounted (compare to the original)
Old 02-19-2011, 02:40 PM
azaytsev
azaytsev's Avatar
How many spray cans of paint did you use?
Old 02-19-2011, 02:48 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Not much. Maybe 1/3 of one. Maximum 1/2.
Old 02-19-2011, 02:53 PM
Dharn55
Dharn55's Avatar
Looks great, I feel a spring project coming on!
Quick Reply: Painting Bumperettes - DIY - (now with after mounted pics)
