Inside Door arm rest reinforcement?
I need to get a set for Garrett's car as his arm rests are broken. So are mine in my S4 but his comes first. Where are they available???
Archive Gatekeeper
Door armrest backing support at 928 International.
That's where I got mine a few years ago. I'll be they'll work just fine if I ever get around to installing them.
Edit: (Wow... 3 responses at the same minute! Is this a helpful forum, or what?)
I can also say that the Loctite Plastic Bonder Epoxy is quite good for repairing cracked/disintegrated Porsche black plastic. I've had good luck with this stuff when attaching sheet metal and such for rebuilding center console tabs, and also with a bit of furnace tape (aluminum foil tape) to cover one side of a hole and then fill in with the epoxy. Once cured, the tape can be removed, and the epoxy drills and grinds well.
MCR 85 928 (01-23-2024)
Got mine from Nicole...very happy with it and you can buy the doors individually... normally the passenger door is fine, usually the drivers door is the one that is busted...
The one I got from Roger has tabs that attach to the mounting studs on the inside of the armrest for the hand hold portion of the arm rest. 928 Motorsports has what appears to be the same version and pics on there website.
http://www.928motorsports.com/parts/armrestsupport.php
Just seemed like a better attachment method than the other one piece kit I had previously installed for another owner which relies on holes drilled through the old armrest plastic exclusively.
I had cracked plastic about midway so the two piece kit did not seem to be the best option for me.
Looks like the same kit. Are all three the same now?
I did the 928I kit and liked the result. You grab the handle and it's a very solid feel. I did have to modify the door panel insert piece to fit afterwards. I would change the bracket next time.
On my other 928, the driver's door handle is feeling a bit soft. I'll probably be in the market for this again.
I reinforced my door panel with model airplane fiberglass and CA glue.
Does anyone think they can't duplicate what these vendors are selling for over $80, with less than $5 of sheet metal from the local hardware store or HomeDepot?
$80 doesn't seem like a lot for being able to focus on the problem and not spend time shears, drills and nice try #3. I'm an enthusiast for "making it work" but think these are a good way to go for broken arm rests.
