996 Forum 1999-2005
Simple 3-step complete coolant drain (updated w/ refill procedure + water pump tips)
Old 01-25-2013, 02:14 PM
Ahsai
Ahsai's Avatar
Default Simple 3-step complete coolant drain (updated w/ refill procedure + water pump tips)
Hi guys,
Just want to share with you I've found a simple way to drain all the 6 gal coolant out. I've looked at other DIYs and even the factory procedures but they all involve disconnecting coolant hoses that are under the car, which requires removing the underside panels. I'm too lazy so I studied the coolant diagrams and came up with a much simpler way.
The total capacity is ~6 gal and you will drain ALL of it if you follow the steps below. Real simple.
1) Remove the coolant reservoir cap and open the coolant drain plug at the bottom of the engine (SOP) and out come ~2.5 gal - all the coolant trapped in the engine block. Now put back and tighten the drain plug to seal the system.
Name:  IMAG0861 (Small).jpg
Size:  51.3 KBName:  IMAG0893.jpg
2) Put a 5gal bucket under the big hose connected to the thermostat. This hose is the coolant return hose from the radiators in the front. Disconnect the hose and out come ~0.5 gal. Now this is the fun part. Introduce compressed air to the coolant reservoir neck (a few PSI will do. DO NOT EXCEED 10PSI. I used a simple rubber gasket to seal it). Be prepared, 2.5gal will gush out with force from the big hose - Congrats, you just drained all the coolant trapped in the front radiators! Basically the air goes into the radiators via the vent hoses and forces the water out from the big return hose.
Name:  IMAG0884 (Small).jpg
Size:  63.0 KBName:  IMAG0866 (Small).jpg
3) After steps 1 and 2, you've already drained 5.5gal (>90%) so you can stop here if you're lazy. For the perfectionists, of course we need to track down that remaning 0.5gal. Where the heck is it????
You guessed it.....it's trapped in the heater core!! There's no valve. Forget about turning ON the heat when draining, etc. The coolant just recirculates the heater core whenever the engine is running. Now go disconnect the heater core coolant supply line from the engine and remove the two bolts holding the hard metal line so you can tilt down the hose like below. Remove the drain plug again and introduce compressed air at the hose side. 0.5gal will gush out from the drain plug and from the metal flange where the hose is connected to. Note this is the ONLY way to drain the heater core because the IN/OUT hoses connected to the heater core are at the top of the core. You can disconnect hoses all day long. Without force, the coolant will just sit at the core.
Now go reconnect the two hoses and tighten the drain plug and you're done
So in summary, the engine holds 2.5gal, the radiators and hoses under the car hold 3gal, and the heater core holds 0.5gal. There's your 6gal
I used the cable operated hose clamp tool and a pick to break the surface between the hose and the metal part. Took me at most 5 minutes to disconnect each hose, if that. i think with practice, you can finish the above within 1/2hr. Note you need the uview vacuum tool to refill now that you've replaced all the coolant with air.
Check out post#15 for refill procedures and some tips on water pump replacement.
Last edited by Ahsai; 01-27-2013 at 04:47 AM. Reason: Added refill procedure in post #15
The following 5 users liked this post by Ahsai:
DSC800 (11-19-2020), dxrohanx (05-09-2023), jdbornem (04-05-2023), mbgt72 (02-12-2020), peterp (10-11-2019)
Old 01-25-2013, 02:31 PM
KrazyK
KrazyK's Avatar
Awesome job. Theres usually a way to improve on the DIY's posted. Makes me wanna go delete my coolant flush DIY. You may want to post on Renntech.
Old 01-25-2013, 03:03 PM
Kazual99
Kazual99's Avatar
Most excellent.
Old 01-25-2013, 03:08 PM
perryinva
perryinva's Avatar
Good idea! Wish I had though of that when I had replaced my WP.
Old 01-25-2013, 03:41 PM
Viper6
Viper6's Avatar
This is simple and complete, well done! I wish I understood the refill method more clearly... can you take a stab at summarizing that with your pics of tools and steps... KISS principle!
Old 01-25-2013, 04:27 PM
Ahsai
Ahsai's Avatar
Thanks, guys!
@Krazy - thanks for the positive comments and not being offended. I always enjoy your DIY posts. I saw your coolant post on renntech but my ramps on my mid-rise lift are blocking the underside panels so I was forced to improvise...Btw, keep up with your great DIY posts
@Viper - I'll replace the water pump and refill the system this wkend. I'll take some photos and add them to this thread.
Old 01-25-2013, 11:21 PM
philooo
philooo's Avatar
Brilliant !
All of us need new water pump and the coolant flushing is always a pain
Old 01-26-2013, 12:34 AM
Ahsai
Ahsai's Avatar
Thanks Phil! I plan to replace the coolant every few years. They are $30/gal + shipping from Sunset so it's a little over $100. Not too bad.
Old 01-26-2013, 08:43 AM
philooo
philooo's Avatar
BTW, about the coolant type to use, I see plan to buy from sunset... is there anything we can use from the advancedautoparts and the like ?
I see they are mostly blue and yellow at the local part store and it seems to be pink/red in our porsche...
Old 01-26-2013, 11:53 AM
TomF
TomF's Avatar
Outstanding write up!
Thanks for this. I was actually looking for a similar solution yesterday and you beat me to it!
Cheers,
TomF
Old 01-26-2013, 03:06 PM
Ahsai
Ahsai's Avatar
You're in FL? Suncoast may be cheaper. You need to check though. Except for brake fluid and engine oil, I stay with the OE fluid because I don't have the expertise and time to do experiments on my own car. I remember Logray and Doug have used non-OE so you may want to search their posts.
Cheers,
TomF
Thanks, Tom. Let us know if you find an easier way.
Old 01-26-2013, 03:26 PM
redridge
redridge's Avatar
very cool, thanks for sharing... One thing I dont understand, that Porsche thinks that these 911 dont coolant flush... the dealer told me they dont do flushes as regular maintenance.
Old 01-26-2013, 03:47 PM
KrazyK
KrazyK's Avatar
You can get Pentosin Pentofrost at Oreillys. They call it purple but its really more pink colored. Make sure you get the Porsche approved version of it.
Old 01-26-2013, 04:15 PM
Ahsai
Ahsai's Avatar
Because they knew sooner or later you're gonna need a new coolant tank or water pump at which point the coolant will be replaced partially anyway
Once I asked a service advisor if I should replace the coolant sometimes. He said, no worries, you're gonna need a new coolant tank down the road anway. Sure enough, my tank leaked not long after and needed replacement.
Old 01-27-2013, 04:44 AM
Ahsai
Ahsai's Avatar
So I replaced the water pump and the thermostat and refilled the system. All buttoned up and tested. Everything seems fine. The impellers are fine but the bearing has some noise. Originally I just wanted to replace it as a preventive maintenance. Turned out I caught a soon-to-fail part. So quite happy about that.
The refill procedure was quite straightforward.
1) Vacuum the system down to ~27 PSIG shown by the gauage
2) Mix the coolant - 4 gal mixed in the bucket and 2 more gals ready in bottles
3) Check if the vacuum holds
4) Prime the uview coolant filler tube. Submerge it in coolant and then connect it to the head unit. I placed the bucket a little higher than the reservior neck. I had to hold down the pickup hose so it stays at the bottom since it tends to rise up by itself. Never let the hose suck in air during refill.
5) Pour the 2 gal bottles mid-way. Almost all 6 gal went in (1.5L left so will see if I have some air in the system).
Size:  212.4 KBName:  IMAG0913.jpg
Size:  109.2 KBName:  IMAG0919.jpg
For the notorious water pump bolt, I used a 1/4" drive 10mm deep socket to break it loose. Then I used a 1/4" swival 10mm socket + a 3" extension to unscrew it completely by fingers. No need to attach it to any ratchet.
Size:  141.2 KBName:  IMAG0899.jpg
I found the gearwrench ratchet wrenches very useful for the engine bracket bolts. Also, I was able to use a Snapon 3/8" drive semi-deep 10mm socket 3/8" drive + an in-lb torque wrench to torque down all 7 water pump bolts.
Quick Reply: Simple 3-step complete coolant drain (updated w/ refill procedure + water pump tips)
