2014 specboxster spec tires?
10-18-2013, 10:50 PM
Noticed that spec miata, spec 944 and honda challenge have/are moving to RRs, any thing in the works for specbox?
10-21-2013, 12:18 PM
The Toyo RR has been proposed as the potential new spec tire for SPB across Nasa and PCA for 2014.
10-21-2013, 03:14 PM
can we run custom headers yet?
10-21-2013, 04:24 PM
I'm in....Rennlist Member
Quote:
Originally Posted by
Paul 996
For PCA, I believe that it's been proposed as an "alternate" spec tire.
10-21-2013, 11:35 PM
Heard today that the tire option was out.
10-22-2013, 12:15 AM
jdistefa
Only if you swap out your turbo for a bigger one!
10-22-2013, 03:17 PM
10-23-2013, 10:53 AM
Former Vendor
The Toyo RR would be a great choice for a Spec tire. Fast, inexpensive (relative) and 30% longer life than others in the category that are a molded DOT tire.
10-23-2013, 09:29 PM
Perfect AngelRennlist Member
Phil, are they available in our sizes yet?
10-23-2013, 09:44 PM
Vonschmidt
Confirmation? Are rules being discussed somewhere?
10-23-2013, 11:29 PM
Rules apparently closed. Understand they will be published 1 November
11-15-2013, 05:01 PM
Any further info about tires? 2014 rule update doesn't mention anything.....
11-19-2013, 12:47 AM
RA-1 for 2014, RR to be tested when tires become available and considered for 2015
11-22-2013, 02:27 PM
scratch that...current proposal is Toyo RR will be the spec tire while allowing racers to burn their RA-1s in limited use for a short term.
11-22-2013, 07:18 PM
Former Vendor
The new 17" RR sizes have been ordered they are due to be released Dec 6th, we should have them right around the 13th or 16th ish.....
