Spec Boxsters For info sharing on this exciting new class
Roof Nets
Old 11-11-2014, 10:45 AM
sbelles
I'm in....
sbelles's Avatar
Default Roof Nets
Does anyone know of a manufacturer who has designed a custom roof net for the Boxster per the new rules?
Old 11-11-2014, 06:03 PM
BigKraut
BigKraut's Avatar
Great question! It would eliminate the hassel of dealing with arm restraints.
A quick search didn't yield much but here is some info I found and links to possible sources for the nets.
Threads:
http://forum.chumpcar.com/index.php?...-buy-roof-net/
https://rennlist.com/forums/racing-a...of-panels.html
Sources:
http://www.teamtechmotorsports.com/
http://rjsracing.com/
I wonder if using metal hose clamps to secure the net pictured in the RennList thread would meet the spirit of the new rule.
Old 11-11-2014, 06:33 PM
sbelles
I'm in....
sbelles's Avatar
Thanks Brian. My quick search didn't yield much either so I took the lazy way out. It would be very nice to ditch the arm restraints.
Old 11-17-2014, 11:05 AM
consolidated
consolidated's Avatar
I've looked too, the challenge will be finding someone who can certify the thing, but if they can make a generic SPB pattern perhaps it will be worth their while.
edit: I've contacted Teamtech to see if they will make one for us.
Old 11-17-2014, 01:09 PM
sbelles
I'm in....
sbelles's Avatar
I contacted them too. I could be wrong but I don't read the rule to say that the net needs to be certified, just that it be "appropriately" constructed of certified materials by someone who knows what they are doing.
The arm restraint requirement does not apply to Boxsters equipped with the allowed aftermarket plastic top as long as a custom fabricated roof net, filling the halo area of the roll cage, is installed. Custom fabrication means that a template of the actual roll cage halo area has been sent to a manufacturer of SFI or FI A approved webbing goods, and that the product is appropriately constructed and attached to the halo bars on all four sides with webbing and metal buckles. The use of plastic tie raps, plastic straps or elastic cords is not allowed.
Old 11-17-2014, 01:32 PM
Dave DE
Dave DE's Avatar
Do you guys plan on having loops on all 4 sides, or just 2 sides like a window net? I see they need to be attached on all 4 sides, but I'm not sure loops would be necessary on the short sides.
Old 11-17-2014, 04:37 PM
sbelles
I'm in....
sbelles's Avatar
I assume that they will but I'd also like to see a loop in the corner of the front to connect to the diagonal bar.
Old 11-24-2014, 02:47 PM
Sean Gibbons
Sean Gibbons's Avatar
I have a source to have them made. They will be between $250 and $300. Let me know if you want one. Need to make a template of the roof cage to have them built for your car.
Old 11-24-2014, 07:36 PM
Deadeye
Deadeye's Avatar
We used two large window nets and rivetted them together. A stainless steel cable around the perimeter and clamped to the cage halo. Worked for chump car skruts.
Old 11-27-2014, 07:19 PM
thstone
thstone's Avatar
Here is a pic of my custom fab roof net that was made during the build. This has been accepted by the POC and PCA.
Old 10-29-2015, 01:38 PM
audipwr1
audipwr1's Avatar
I'd like the buy the above roof net, how do I go about getting one?
Old 10-29-2015, 08:30 PM
bkovac
bkovac's Avatar
Had mine made by Team Tech, just under $300 for my boxster
Old 10-30-2015, 01:01 PM
Cory M
Cory M's Avatar
teamtech made mine too
Old 11-09-2015, 01:20 AM
thstone
thstone's Avatar
Contact Eric at Hergesheimer Motorsports in Lake Forest, CA.
Old 11-10-2015, 01:43 PM
eric523
eric523's Avatar
Yes, I've had a handful made at Teamtech for our Boxster Spec builds (including the one in the photo above). They come with the sewn in straps(14), as pictured. The size is 24" x 36" and fits our cages well, which have the windshield bar stitched to the windshield frame. I retail them at $215, but I am currently out of stock. I can get a half dozen on order if you guys would like, and they should be ready in a couple of weeks for shipping.
They do NOT come with a certification tag like the standard window nets but are of course made with the same material. They have passed through POC/PCA/NASA tech several times.
I also have one used net available in the same size with open ends, like a standard window net that you could use with steel cable. I had that one installed on my car before we went to the sewn in straps. I'll sell that one for $75 if anyone wants to go that route instead. It's just more a pain to install and uninstall when needed.
Quick Reply: Roof Nets
