Oil of choice?
I also check the oil filter for debris after every event. It can be removed with only minor oil loss.
Lots of good and valuable info here. Thanks. I've already ordered a sample kit from Blackstone Labs and have registered for the Millers Oils contingency program. Thanks again for the feedback.
I use Blackstone Labs to confirm my decision on frequency of changing oil....use 10W-50 Brad Penn semi-synthetic race engine oil...run 15-20 hours per sEason and the change oil and no issues and lab results show no negative issues.
I'm confused. Spec Boxster doesn't run a "race engine." Engines are stock, per PCA rules. While I can understand using an expensive oil for an enduro weekend, why would you do a $200 oil change after a sprint weekend that maybe puts a few hundred miles (and 2 engine hours) on the car?
Gary. Here's the best cheap insurance. $3k donor car with less than 50k miles. The real beauty of spb. Just flog it, and slap in another one if she blows. Three seasons and still running strong, and I haven't seen or heard of any spb engine explosions in that time amongst my buds in the northeast. I really think this issue is way over blown. (As long as you follow the basic recommendations with regard to deep sump pan, ims upgrade, and accusump). I run redline and change oil every three events (maybe every other if I run the enduro)
Glen, your buddy and fellow bumper rubber blew a motor at VIR this year. Although, it was likely the result of the hot weather we had this year at VIR. I lost a transmission at that race weekend also, likely heat related also.
I personally use Redline oil in my car. Oil life is only part of the equation when looking at oils. I change my oil after every race weekend, as others have said, cheap insurance. I also run a different, bigger filter that has been relocated to the trunk.
I'm in....
