Spyder/Cayman R Discussions about the 987 Spyder/Cayman R (2011-2012)
New to me Spyder
Old 08-16-2023, 10:35 AM
Patrick3000
Patrick3000's Avatar
Big shout out to Casey and the gang at Porsche of Silver Spring.
I took the BS in for a MSSI and they ended up basically doing a PPI, post purchase inspection. Thank you 😊
The car needs a major service (the tech took the time to review the detailed service records that came with it) and she needs tires due to age.
They went ahead and fixed a couple of minor issues, switch for the frunk (the one in the door sill) was replaced ($256) and a new key ordered ($622) car only came with one key 🤷‍♂️
I’ll drop it off for the major service and I have a Numeric shifter to install when the second key arrives from the fatherland. I have the shifter leftover from one of the 997’s that I regretfully sold and just need to purchase the 987 cables ($511)
I’ll throw on a set of Michelin PS2’s, N spec when I have the opportunity and we are all set for commuting 😁
There is also a blemish on the drivers seat bolster from improper entry into the car and a small imperfection in the base of the driver’s seat, the upholstery shop at the dealership said that they can fix both issues for ($250)
Following completion of the service, car should be in “new” condition 🤩
The miles are already piling up, 700 and climbing in week one, love this car. Perfect for running around the beach and driving to work 😊
SCMike (08-16-2023)
Old 08-16-2023, 11:33 AM
Patrick3000
Originally Posted by SCMike
If you really want to get obsessive/compulsive about the documentation , here is what came with my ABM Spyder:
Thanks to the the helpful guys in the forum I have found a few items, ($177) still searching for items circled in red.
If you have any leads, they are appreciated 😋
Old 08-16-2023, 12:12 PM
AWay
AWay's Avatar
I'm sure if you keep an eye out on ebay you can scoop a PCM manual for these generation cars. Same with the roadside manuals as neither were specific to the Spyder. The Porsche CPO owner cards and inspection checklist would be specific to your car so if it was a CPO previously the only way to obtain them would be to ask the seller you purchased from. Finding a different set second hand won't help you there.
Patrick3000 (08-16-2023)
Old 08-16-2023, 12:51 PM
Patrick3000
Just thought I would ask here first. You know how some like to collect stuff. The PO could not locate the documents at the time of sale, they may turn up at some point. The car came out of Beverly Hills, I believe CPO for the PO, they have been asked to locate any available docs.
Just covering all the bases 👍
I am a bit OCD about this stuff 🤷‍♂️
btw: thank you for the link yesterday the Owners Manual and case are in route 😀
Old 08-16-2023, 01:03 PM
AWay
AWay's Avatar
Oh great, no trouble at all. Just keep an eye out or setup a search and it'll ping you when one pops up. They'll turn up.
Old 08-18-2023, 04:48 PM
Zach L
Zach L's Avatar
PCM booklet would have only been included if the car was optioned with PCM aka navigation. Since your car is a "low option build" that probably isn't needed.
Old 08-18-2023, 05:00 PM
John McM
John McM's Avatar
My PDK car had the above as well as these.
Old 08-18-2023, 05:18 PM
Patrick3000
Excellent and you are correct, no PCM in my car 👍
Thank you 🙏
Old 08-19-2023, 02:09 PM
Spyder_2011
Spyder_2011's Avatar
Being the original owner I have all the documents, let me know if you think you’re missing something and I can post some pictures.
Patrick3000 (08-21-2023)
Old 08-26-2023, 01:09 PM
MezgerFan
MezgerFan's Avatar
@Patrick3000 Congrats on the Spyder!
Are you sure you want to go with PS2 tires? I understand the N rated motivation, but tires have come a long way since the PS2s were introduced 20 years ago. I have non-N rated PS4S on my car and they are fantastic.
Old 08-26-2023, 01:20 PM
AWay
AWay's Avatar
Porsche continually updates its tires just FYI. So while the PS2 may technically be an ‘older’ tire name it has been completely revised by two subsequent generations. The original PS2 being N0 designation then N1 and currently N2. I just put a fresh set on mine and couldn’t be happier. Same cost as PS4S as well.
Not to sway in one direction or the other, purely informational.
MezgerFan (08-26-2023)
Old 08-26-2023, 01:26 PM
DaveGee
DaveGee's Avatar
I’m counting on it. Installation is scheduled for Tuesday.
DaveGee
Old 08-26-2023, 01:48 PM
Zeus993
Zeus993's Avatar
Received 1,243 Likes on 573 Posts
Just did the same. Beautiful new PS2 - N2's.
Old 08-26-2023, 03:10 PM
Patrick3000
Thank you, love the Spyder 😊
Yes absolutely sure, I have spent three hours with the Michelin tire rep in briefings discussing tire construction and the various compounds that go into the various types of tires. Bottom line if you want performance PS2’s comfort and longevity PS4’s.
The following 3 users liked this post by Patrick3000:
John McM (08-26-2023), Spyder_2011 (08-27-2023), Zeus993 (08-26-2023)
Old 08-27-2023, 11:09 PM
Zach L
Zach L's Avatar
Yep, unless it's a heavily driven daily driver... PS2 > PS4S
Patrick3000 (08-28-2023)
Quick Reply: New to me Spyder
