RS Door Panel Removal [VIDEO]
Hey everyone,
I really didn't see this documented too well online so I wanted to pay it forward for the next guy. Hope this helps someone out. Cheers!
The following 3 users liked this post by DasCayman:
I didn’t want the next person to bend their metal bracket because it will require you to remove that interior metal cover and bend it back in place.
cheers
islaTurbine (04-06-2024)
Hey everyone,
https://youtu.be/Awg6eMhLqjI
Thanks again.
JP
Nice job, thank you for putting this together.
Thanks for the response. This is what I originally did and there was a lot of stress on the interior metal door panel where the foam door panel rests / hangs on. It’s like a French cleat. I ended up bending this interior metal trim which I why I recommend popping the bottom of the panel off first and then sliding the cosmetic door panel up and off the metal cleat. Similar fashion / methodology to the triangle door mirror trim piece.
cheers
cheers
The process is to unlock the plugs first (they have two positions), with the correct tool, then the door panel lifts up and free easily.
As per the instruction sheet above; just follow the A, B, C sequence.
There's numerous video and similar on the internet describing the correct process, as pulling on the top first would likely damage the fittings, yes.
