Spyder/Cayman R Discussions about the 987 Spyder/Cayman R (2011-2012)
Boxster Spyder 987 - What is this?
Old 04-15-2017, 04:38 PM
MarktheShark
MarktheShark's Avatar
Default Boxster Spyder 987 - What is this?
Found this 1" rubber component on my passenger seat. Seems simple - but haven't been able to identify where it goes? Anyone know?
Thanks, Mark
2011 Boxster Spyder
2006 Porsche Cayenne S
1982 928
Old 04-15-2017, 09:12 PM
Marine Blue
Marine Blue's Avatar
Is that the end cap trim on the end of the door? That's my best guess.
Old 04-15-2017, 11:17 PM
DaveGee
DaveGee's Avatar
It's the end cap for the CF frame of our sun cover (top). Mine fell off a few months ago. Twice. Then I glued it in place. No problems since.
DaveGee
Old 04-19-2017, 07:47 AM
itsujack
itsujack's Avatar
I've lost one of these, tried to track down the part number but doesn't seem to be identified separately from the CF frame? If anyone has any idea on part numbers for left and right would be appreciated.
Old 04-19-2017, 05:00 PM
bassie81
bassie81's Avatar
Try this site
http://www.porsche.com/all/media/pdf...W_DE_987-2.pdf
Old 04-23-2017, 11:25 PM
itsujack
itsujack's Avatar
Originally Posted by bassie81
Thanks very much for the link. I had been using the Auto Atlanta site for part numbers which I think references this document. I would expect to find the part numbers on 811-08, but they don't seem to be referenced which makes me think they cannot be purchased separately? I took a punt and ordered part 11 on 811-10, but no luck, these are for the regular Boxster roof. Note for anyone's future reference, these numbers below are NOT the correct numbers for the Spyder:
98756181302
98756181402
(if anyone needs these parts let me know, they're useless to me)
Time to give up and call my Porsche dealer...
Old 04-24-2017, 04:07 PM
bassie81
bassie81's Avatar
Search the document for 'spyder' for quick navigation..'
Old 04-25-2017, 10:44 PM
MarktheShark
Thanks for all the replies. DaveGee - could you post a picture of what the piece looks like attached. I must have lost the other side as well - as I do not see where the piece attaches.
Thanks, Mark
Old 04-26-2017, 04:39 PM
DaveGee
DaveGee's Avatar
Sure, here you go.
And if this pic shows up upside down or sideways, I welcome tips on how to prevent it from happening.
DaveGee
Old 04-26-2017, 11:09 PM
MarktheShark
Thanks DaveGee - Mystery solved! Fortunately I do still have the other side intact. Not the most obvious location to spot. And I'll also take the advice re: glue too.
Mark
Old 06-29-2017, 10:47 PM
itsujack
itsujack's Avatar
Does anyone know the part numbers for these (I've now lost the other one!)? They do not appear anywhere in the PET...
(I can confirm that the following are definitely not the right parts: 98756181302 98756181402)
Old 10-06-2017, 04:28 AM
itsujack
itsujack's Avatar
Finally got an answer on these. The rubber end caps are not available separately from Porsche, so make sure they are glued in nice and snug!
Local dealer said they are only available with the entire rubber seal for the CF roof, this little strip of rubber is only $765AUD... think I can live without the end caps now.
Old 11-20-2017, 12:37 PM
Ale_72
Ale_72's Avatar
I am in the same position. Plugs lost
Confirmed that there is no way to get those without buying 1/2 car?
Old 11-20-2017, 04:03 PM
FlamsteadHill
FlamsteadHill's Avatar
Take a Spyder for a test drive and "borrow" them. Or, slightly less illegally, return them after 3D scanning them so you can re-pop them.
Old 11-20-2017, 07:49 PM
Marine Blue
Does anyone know if these pieces are glued in place or if they are press fit?
I would be willing to pull mine out if someone has the capability to reproduce them but only if they are press fit and can be safely removed.
Quick Reply: Boxster Spyder 987 - What is this?
