Brey-Krause Harness Bar Mount
For SaleAccessories
Unit is used. Used on my 996 c4 many years ago.
From website
The 996/997 harness mount bar has been tested and certified by an independent lab to handle the types of forces required by the National Highway Traffic Safety Admin. DOT and SAE J385 Rev.MAR 95, Motor Vehicle Seat Belt Anchorages-Performance Requirements. The 996/997 harness mount bar properly locates and supports racing shoulder harnesses relative to the driver. In the case of an accident, it helps protect the driver's shoulders and spine. The harness guides also prevent excessive shifting and fatigue of the driver during the high G loads of cornering and braking. Our bars are easy to install and remove, use only existing holes and mounting points, and will not damage the car in any way.
Strength requirements for harness mounts are considerably greater than those for harness guide bars since they must support the entire load applied to the belts. A mount really can't be relied on unless it has been tested to support the loads required by the National Highway Traffic Safety Administration.
Material: Type 304, stainless steel
Finish: Powder coated in durable black wrinkle-finish
Weight: 16lbs. 7oz.
Models: 996/997 Coupe NOTE: Fo
