1991 Porsche 944S2 Cabriolet
For Sale1991 Porsche 944
Price
$13,000
- Location Olathe, KS, 66062, USA
- Condition Used
- VIN WP0CB2947MN440315
- Mileage 96,200
- Engine 4 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Convertible
- Exterior Color Red
I am listing this very nice 1991 Porsche 944S2 Cabriolet for a personal friend that has owned the Porsche for over 13 years. I've personally owned over 30 Porsche's to include at least six 944's so please feel free to ask any questions. The Porsche is in my garage and is available for personal inspection. Pre-purchase inspections are also welcome.
1991 Porsche 944S2
· 1 of 562 S2 Cabriolet's sold in the USA in 1991
· 96,200 Miles (miles may increase slightly)
· All original single stage Guards Red Paint
o Accident free
o No rust
· All original black interior
o No dash cracks
o Power Seats
o Upgraded headlights
· Original Window Sticker
· Current owner since October 2007
o Clear title in hand
Service History Highlights
· 2020 - 96,000 Miles
o Oil and filter
o Brake fluid
o Gearbox service
o Hood Struts
o Odometer Gear
o Headlight upgrade
· 2018 - 95,057 Miles
o Replaced Door Actuator Rods
o Replaced Battery
· 2017 - 92,734 Miles
o Oil and filter
· 2016 - 89,340 Miles
o Replaced Engine Mounts
o Oil and filter
· 2015 - 88,164 Miles
o Replaced Tires
o 4 Wheel Alignment
o Oil and filter
· 2014 - 87,132 Miles
o Oil and filter
o Retension Timing Belt
· 2013 - 84,027 Miles
o Replaced Engine (of like miles to original)
o Oil and filter
o Replaced timing belt & Rollers
o Replaced water pump
o R134 Conversion
o Replaced A/C Receiver Dryer
o Replaced Alternator Belt
o Replaced Power Steering Belt
o Replaced Front Crankshaft Seal
o Replaced Clutch
o Replaced Upper & Lower Radiator Hose
· 2010 - 79,987 Miles
o Oil and Filter
o Adjust rear hatch cable
· 2009 - 77,303 Miles
o Oil and Filter
o Tighten drivers side front wheel bearing
o Replace clamp at Power Steering Pump
· 2008 - 76,128 Miles
o Replaced Fuel Lines
o Replaced coolant
· 2003 - 75,129
o Installed new radio
· 2003 - 74,866 Miles
o Replaced valve cover gasket
· 2002 - 71,084 Miles
o Replaced rotor and pads
o Replaced plugs and distributor cap
o Replaced air and fuel filter
o Oil and filter
· 2001 - 65,988 Miles
o Replaced Clutch
o Replaced Power Seat Switch
o Oil and filter
o Gearbox service
· 2001 - 66,506 Miles
o Replaced Timing Belt/Rollers
o Gearbox service
· 1999 - 58,755 Miles
o Replaced Battery
o Replaced Window Switch
o Engine Tune Up
o Fuel Injection Service
o Brake service
o Gearbox service
o Valve cover gasket
· 1998 - 52513 Miles
o Oil and filter
Can you confirm regarding engine.
“Replaced Engine (of like miles to original)”
What documentation do you have to show engine has similar miles to what was replaced
why did the engine get replaced?
do you still have the original engine?
thx
The engine was replaced by a reputable local repair facility that can discuss all the particulars with you as the repair facility sourced the engine. The repair facility knew the Porsche where the engine was sourced and thus the miles as well. I have the receipts where all the ancillary work was completed by the same repair facility as well.
Best,
The engine replacement was done by arguably Kansas City's top independent mechanic, and as mentioned by ThePorscheGuy, comes with all the paperwork.
Someone is going to get a VERY nice reliable 944S2 Cab.
