2003 Porsche Turbo 1000HP
For Sale2003 Porsche 911
Price
$65,000• OBO
- Location Atlanta, GA, 30077, USA
- Condition Used
- VIN WP0AB29923S685168
- Engine 6 cyl
- Drive Type AWD
- Transmission Manual
- Vehicle Type Coupe
- Exterior Color Silver
I'm selling my built 1000+ hp 996 turbo. Motor and transmission have over 2k miles on them with the fresh build plus motor can handle well over 30psi and 1500hp. Dyno runs range from stock wastegate pressure around mid 700awhp to the max boost on these turbos at 30psi made 1030awhp. I have a list of things that have been done to the car.
Performance Upgrades:
Xona HTZ 61/56R Ball Bearing Turbos
Dual Tial Q BOV's
Protomotive Y Pipe
Protomotive 3inch Exhaust
Protomotive 5.2inch Intercoolers
Protomotive Tune
CSF Radiators
74mm IPD Plenum
997 Short Shifter
Suspension And Big Brake Kit:
Bilstein PSS10 Adjustable and Ride Height Coilovers
Bilstein Front End Links
Bilstein Rear End Links
H&R Front Sway Bar Adjustable
H&R Rear Sway Bar Adjustable
Stoptech 355x35mm Front Rotors
Stoptech 332x32mm Rear Rotors
Stoptech 6 Piston Front Calipers
Stoptech 4 Piston Rear Calipers
Fuel System:
E85/93 Fueling
450lph Dual Walbro E85 Fuel Pumps
8an/6an Steel Braided Fuel lines
Aeromotive Fuel Pressure Regulator
Aeromotive Fuel Filter
1780cc Bosch Injectors
SRM Billet Fuel Rails
Bill Radar Transmission Build And Clutch:
CM Twin Disc Clutch
AASCO Flywheel
1st Gear GT2RS
2nd Gear GT2RS
3rd Gear GT3RS Straight Cut
4th Gear GT3RS Straight Cut
5th Gear GT3RS Straight Cut
6th Gear GT3RS Straight Cut
Billet Mainshaft
Billet Shift Forks
New Reverse Gear
3.8L Motor build:
CP Pistons
LA Sleeves
Carillo Rods
GT3 Oil Pump
New Bearings
New Crank
12mm Head Studs
Built Heads:
Stage 2 Cams
Intake 315 Degree 11.1mm Lift
Exhaust 290 Degree 11.1mm Lift
Dual Springs
Oversized Valves
Port And Polished
New Guides
New Valve Seals
Exterior:
Carbon Fiber Hood
Carbon Fiber Front Splitter
Carbon Fiber Side Scoops
Carbon Fiber Side Skirts
Carbon Fiber Wing
Carbon Fiber Mirrors
Smoked LED Tail Lights
Smoked LED 3rd Brake Light
LED Side Markers
Interior:
OLED Boost Controller
Blinder Laser Jammer
Recaro Custom Racing Seats In Leather
4 Point Roll Bar
Schroth Harness
Carbon Fiber Interior Parts
Replaced Parts:
New Alternator
New O2 Sensors
New Oiler Cooler
New Engine Mounts
New Clock Spring
New Accumulator
New Panels Under Car
New Heater Core
Hey there,
Thank you so much lots of work went into this build. No reason to sell but i want to do a new project i have owned the car since 2012. Stock ECU still with Protomotive Tune both E85 and 93 octane tune and right now i leave it full E85.
I uploaded more pics also....
