A pristine and unmolested 2002 Porsche 996 Carrera 4 (4WD) Cabriolet, in the highly-desirable Lapis Blue Metallic and Savanna Beige supple leather interior, with 6-speed Manual Transmission. MSRP of $103,695.
FACTORY OPTIONS P05 Advance Technic Pckg, 662 Porsche Comm Mgmt, P01 Comfort Pckg, 411 18” Lt Alloy Carrera Wheels, X76 Aero Body Panels (flared), 982 Supple Full Leather, P14 Heated Seats, XPB Wood/Leather Steering Wheel, Y07 Wood/Aluminum Brake/Shifter, E3 Lapis Blue Metallic, SD Savanna Beige Full Leather Interior,V4 Metropol Blue Top
RECENT WORK (all in 2019-2020) - IMS Bearing replaced (was not needed, but done anyway) - Complete clutch system replaced (Flywheel, Pressure Plate, Disc, Bearing) - Rear Main Seal replaced - Water Pump replaced - Strut-top Bearings replaced (all 4)
- Engine Mounts replaced - Front Drive Shaft replaced - Powder-coated wheels in factory color - 4-wheel aligned - New dust-free brake pads all-around - New ContiExtreme Contact DS Tires - Pioneer Audio 7 Navigation System with Apple Carplay and Android support (have the OE Unit)
- Cabrio top hydraulic system rebuild (hydraulic rams, fluid, fitting, etc.)
- Replaced the clutch-assist spring/canister
ALL fluids and lubricants have been replaced within the last 12 months with OE- or higher-spec material (e.g., LiquiMoli, Pentosin, Porsche, etc.)
The car has a few very minor surface scratches and chips, and interior trim has minor wear marks around the inside driver door pull, ignition switch and various controls / levers.
Comes with Build Sheet, Manuals and two keys.
PLESE NOTE: I will be out of country 04/19/21 through 08/3/21, and will not be able to show the car or arrange for a PPI during that period.
Beautiful car. Are you open to a local PPI? Been looking for this color combo. If its still posted you say it is available, lets start chatting, I am ready to pull the trigger.
Thank you.
apf232,
Thank you for your interest and inquiry. Unfortunately, I will be out of country for 3 months starting this weekend, and will not be able to accommodate. I will revise the post accordingly. I posted the car last December and you are the first serious interested party. Regrettably, timing is an issue.
Bahman
That is a bummer. I am new to Rennlist. I cant believe nobody has snatched this up. When will you return to the US? If this car is in as great a condition as you say, I may be willing to wait until you get back. I am in CT, but not too far to go for something you want. Not sure of the Rennlist rules, but is there any way to have a quick phone call before you leave? Thanks so much. Andrew
It is a bummer. I am pretty sure there are many nice ones on the market now. Have you tried pcarmarket.com? It’s a legit Porsche-primarily auction site run by Porsche enthusiasts.
yes, I scour them all Pcar, bring a trailer, cars for sale, car gurus, ebay, craigs list, auto trader. If you dont hop on it the day it is posted, its gone. I am very serious about keeping me in the loop about when you are returning, I have been looking for a few months, seen many, PPI'ed a couple, but alas either turned down a car or been outbid. So if you are going to be back in a few months, patients is a virtue. How can we stay connected?
Bahman - thank you. will keep the number and if nothing happens before then, I will buzz you. 8/3 is my daughters birthday, so maybe that is a good sign. Thanks again, travel safely. cheers, Andrew
