Enco Milling Machine Drill Press 24" bed
Miscellaneous
  • Miscellaneous - Enco Milling Machine Drill Press 24" bed - Used - 0  All Models - Jersey City, NJ 07306, United States
997_rich is offline
    $1,300
  • Location Jersey City, NJ, 07306, USA
Not exactly Porsche - specific but I've certainly used it a lot on my p cars.
Used but in great shape. 24" long bed,  Still has good runout tolerance. Manual operation. Wired for 110V. Forward and reverse, multi speed. Has a drill chuck installed but has a standard tapered collet that can accept almost anything. Comes with a welded steel base. Also comes with clamping set, vise, pillow blocks etc. ---- everything you see in the pictures. It's a really nice middle weight milling machine that's much more powerful than a jewelers press so you can do some heavier work but doesn't take up a huge space that a Bridgeport would.
Sold as-is but feel free to run it a bit in my garage before you take it.
located at 07306. Ideally you pick up but I can potentially break-down and deliver in the NYC area for a small charge.
Is $1700 on ebay but selling at a deep discount to rennlisters.
