Techart Championship Formula Wheel set 18 x 8.5 / 11 for NB 993 - Mint Condition!
For SaleWheels and Tires/Axles
I think it’s time to sell the TECHARTs AGAIN.
Specs:
- Techart Championship Formulas made by OZ Wheels (known as the OZ Mito Modular for non-Techart fitments)
- 18x8.5 et40 x2 Fronts
- 18x11 et60 x2 Rears
- 5x130, 71.6mm CB
- Porsche NB 993 fitment
The rears were originally a 10” wide et47.5 but we widened them using a 1” wider rear lip (2”) which effectively gives them an offset of 60.
The entire set was disassembled, cleaned, straightened, refinished all 4 centers w/ new painted Techart logos, refinished front & rear lips, refinished front inner barrels, new rear barrels, and reassembled with new hardware. Never mounted tires.
All work performed by Dave @ @renewedfinishes (on IG) They are meticulous and perfect. I only removed the cling film to stare and drool over them 🤤
The original center caps were trash so I have 4x new aftermarket center caps that shape in quite nicely, and 4x new ‘OZ Wheels’ gel badges… which is the exact setup I ran on my old wheel set. I prefer the black center personally but if you want (and can find) some Techart logo badges, go for it… just pop em on these new caps instead!
These were spec’d for my NB 993 to run with 225/40 and 285/30 respectively. I assure you they will fit a narrow body 993 but **clearance will widely depend on your vehicles ride height, alignment specs and the brand of tires you run**, as some 285s are meatier than others. Front fit fine with 225/40 but have been know to be fine with wider tires
I had this exact same size spec setup on my (quite low) NB 993 with Pirelli PZero Rossos in those sizes and they fit splendidly… pics for reference. Those tires are not skinny little narrow rubber bands.
These will fit Wide Body 993s too but ideally with spacers as running wider tires will be tight on the inner suspension and inner fender well.
Will likely fit early Boxster and NB 996/997 just the same… but I do not know… probably better with spacers on rear for WB.
For everything else, I don’t know. Google it. Search Function is your friend. Do your own research for anything not-NB 993.
These will NOT fit on standard 964s as they hit the passenger side inner oil lines.
$6500 SHIPPED in 48 lower US. Local pickup preferred and will meet within 50 miles.
DM me for contact info.
- Rich
